Change Driveline Fluids Early!
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Thank you everyone for your advice. Everything worked great! Amsoil 75w-140 F&R, BG Syncroshift II in the manual transmission, Ford Mercon LV in the transfer case. 23,000 miles, better late than never.
I’m running the same exact combo.
Ziemann
Northern Wisconsin
'23 Ford Bronco 2-Door 2.3 MT
BG Synchroshift II is like butter in these MT88 manuals. Good choice. :cool:
B22-2023
Houston
I took today to complete front differential, transfer case, and rear differential fluid change at 4700 miles. As others have reported, I too found the rear differential in need of fresh lubricant. Replaced transfer case fluid with Motorcraft Mercon LV and both differentials with Valvoline synthetic 75W-90 fluid in flex packs. Additionally, I replaced the rear differential cover with the ARB unit ($177 shipped from Extreme Terrain) allowing for ease of future fluid changes. Love the magnetic dipstick and ease of filling the diff with fresh fluid using the flex packs.. Also the magnet on the drain plug is a beast!
I put the ARB on also, to get some more strength in the axle line.
As for fill level, are you using the dipstick for reference? To me I’m trying to set a mark that is top of the axle, but I’m curious what you think.
HP11
New Hampshire
2013 Boss 302 (sold) , 2023 Ford Bronco WildTrak
Yes, the cover will definitely provide added strength and I'm using the dipstick after first scribing a line on the dipstick that corresponds to the appropriate stock fluid level. I followed the guideline in the ARB installation sheet to align both covers first.
After installation and filling the differential, I used approximately 1.9 quarts of fluid. Your measurement may be slightly different but in my case the scribed line on the dipstick is 3 3/16” from base of the dipstick knob and 1” from the dipstick tip keeping in mind that when checking the fluid level you DO NOT screw the dipstick back in but rather place it in the opening to a point where the threads just touch... this per the install sheet.
Ford Bronco Change Driveline Fluids Early! 69AE0836-4467-4670-8064-DB01E15469A3_1_102_o
CarbonSteel
CarbonSteel
Colorado Springs
2023 Carbonized Gray
Seems to me like a silly place for TTY. I'll be replacing with regular bolts when I get around to this.
But are they actually yielding here? I would think the gasket would make it hard to stretch them.
Given they are 8MM diameter and are only torqued to about 22-25NM, I would say they are not being torqued to the point of TTY. The gasket does have steel reinforcements at the bolt holes to prevent crushing the gasket and throughout the gasket surface, but the torque values are too low to see TTY especially since they are Grade 10.9 (essentially SAE Grade 8).
They are too short to be used with the OEM gasket and the Ford Performance cover so I replaced all of mine anyway, but can say that I never changed the bolts for AT LEAST 4 times on my Jeep Wrangler which has the same bolts and never had an issue.
SierraBronco
More of a “drivetrain” fluid than differential but decided to change the transfer case fluid since I had the skid plates off to swap out the driveline. 23,000 miles and dang. That stuff was darrrrrrrrrk.
redone17
Cold Spring, NY
Womp. Flange bolts link is dead.
The studs are zinc or black? What’s this yellow coated you speak of?
CarbonSteel
CarbonSteel
Colorado Springs
redone17
Cold Spring, NY
Thanks @CarbonSteel
Looks like all of the links are broken from your original post besides the studs. Which I don’t see in yellow coated either. Did you use zinc?
CarbonSteel
CarbonSteel
Colorado Springs
Thanks @CarbonSteel
Yes, yellow zinc; I'll have to go back and edit the links to current. It appears that Belmetric made sweeping changes to their inventory listings and the links were broken in the process.
redone17
Cold Spring, NY
Ok, I’ll keep an eye out on an update from you.
CarbonSteel
CarbonSteel
Colorado Springs
Wait, I may have misunderstood. Were you talking about the bolts or the studs?
redone17
Cold Spring, NY
The whole list. It’s weird. The stud link works - but only has zinc or black. All other links say “Aw Nuts”. Clever. Haha.
Ford Bronco Change Driveline Fluids Early! IMG_0504
CarbonSteel
CarbonSteel
Colorado Springs
Updated the first page to make it easier to find, updated all links, and tagged you in it...
redone17
Cold Spring, NY
Thanks!!
