- Joined
- Dec 11, 2020
- Threads
- 40
- Messages
- 1,062
- Reaction score
- 1,853
- Location
- Colorado Springs
- Vehicle(s)
- 2023 Carbonized Gray
- Your Bronco Model
- Wildtrak
- Thread starter
- #331
Grab one of these for next time and it will be an easy and clean filling process. I cut about 6" off the tube and it made the job a snap.This last weekend I changed the front diff, rear diff and transfer case fluids. I tried several different ways to put new fluid in and I've come to the conclusion its a mess no matter what.
One thing I wish I would have realized prior to removing the rear diff cover is that the top of the stock diff plate plus the thickness of the gasket holds a lot of dirt and dust. When I removed the cover and all kinds of crud fell down on the gears. I was not a happy camper. Tried to wipe it out the best I could but I know I didn't get it all. Just clean the top as good as you can prior to opening the cover!
I installed the FP Diff cover plus the DV8 diff skid which I had to modify to fit over the new cover. I think it came out pretty good and I have the benefit of the new cover plus protection.
https://www.amazon.com/Hopkins-10106B-FloTool-Filler-Refill/dp/B000EH4UXM
