Alternator 100% destroyed from mudding
NC_Pinz
Central NC
I wonder if anyone is going to develop a liquid cooled alternator for our application. Some high end manufacturers use them. It would give you a sealed alternator.
swooshdave
Portland, Oregon
Mustang
TavisB
Pa
22 ManSquatch, 10 F150
Look at a diagram of the 4.0L engine found in Jeep Wranglers and Cherokees and see how low the alternators were. I've seen a few XJ's over the years with water at hood level that didn't kill their alternators.
I've killed an XJ alternator with mud. It can be done! Lol.
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
Not sure what was worse, Jeep people trying to figure out how an alternator works or the Bronco people complaining that Ford screwed up the design. And they are both wrong.
Was waiting for the anti-Jeep humor on that one. That said they don't seem to be getting to a conclusion anywhere. :D
This seems like a mid-cycle refresh item.
  • Like
Reactions: Jdc
swooshdave
Portland, Oregon
Mustang
At least no one here has proposed filling the alternator with silicone to waterproof it. Yet.
BroncoRick
The other comments here about the differences in water fording vs. sitting in mud are spot on. You have to keep the vehicle moving. If you are going to be playing in mud like this, prepare for part failures and accelerated wear on components. Hub bearings, axle seals, any lubricated joint (sealed or not), idler pulleys, and in the worst case, transmissions, t-case, diff gears, and anywhere else you are carrying fluids. Been there done that enough times I won't do it again unless it is absolutely necessary to get from point A to point B--and in that case have the anchor point and winch or a buddy with a strap ready to extract it as quickly as possible. Rule #1 if there is the possibility to get stuck, don't take it deeper than the hubs without a way to recover quickly.
JBlanco
Julio
Charlotte NC
2023 Bronco BaseSquatch, 2023 Tesla Y Performance
Jdc
Jon
Massachusetts
Bronco Badlands
A thread from almost 20 years ago? What's the point?
Alternators haven't changed much in the last 50 years. That thread just shows it's an issue even for jeepers....or realistically anyone driving through water
JBlanco
Julio
Charlotte NC
That's just shows a desperate attempt to compare the Bronco with a 20 years old Jeep. The alternator in the 2012 and up Wranglers is almost hitting the hood as it has been relocated exclusively for this model. Regardless of the problem being in other vehicles it should not be this way for a new vehicle designed to function off road. Whats next? The 1984 Mitsubishi Montero heads cracked so the 2.7L blowing up in the Bronco are OK... I don't get the need to justify that a design flaw is ok instead of making manufacturers responsible for their products...
Norm A.
Norman
Time to break out the old aqua-net hair spray and water proof before going thru water 😜🍍🍕
Jdc
Jon
Massachusetts
Bronco Badlands
Ford Bronco Alternator 100% destroyed from mudding 1657155098138
Who pissed in your cheerios this morning. I was focusing on the fact that alternators aren't waterproof but if you want a more recent example here you go.
https://www.jlwranglerforums.com/fo...ing-issue-maybe-alternator-please-help.64263/
Now go try some breathing exercises and relax
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
Could be heat related, not sure how close the 2.7 alternator is to exhaust/turbo. Take something hot and quenching it can seize a bearing.
Also these new alternators are high output compared to older alternators. Not as reliable due to amount of current, heat and create more drag.
