2022 Bronco Clutch and shifting problems
mpeugeot
Actually, there's something that doesn't make sense, look at the center of the clutch plate, there is no evidence that it was overheated in a way that would damage the transmission.
Sure, there's evidence that the flywheel was overheated and that the clutch was falling apart, but it also looked like it wasn't getting proper clamping pressure from the pressure plate. This could be manufacturing defect, because it looks like only the edge of the disk was failing.
When the plate is truly overheated, you will see color change evidence in the center of the clutch plate.
look below for examples
Ford Bronco 2022 Bronco Clutch and shifting problems Screenshot_2022-07-30-20-18-21-406
Ford Bronco 2022 Bronco Clutch and shifting problems Screenshot_2022-07-30-20-20-17-461
Ford Bronco 2022 Bronco Clutch and shifting problems Screenshot_2022-07-30-20-20-49-236
TrailRaider
Mr. G
So. Cal
Focus ST, Mitsubishi Montero, Bronco Badlands
That gonna be expensive. I hope this guy is your friend. If not, I hope you have some money in the bank or a high limit credit card. This is one of the reason there are very few people I would let drive my cars, and all but 2 are related to me. The 2 that aren't, I know the risk and would not ask for a penny from if something like this happened. Very unfortunate, but your dealer is correct. That being said, if I were the service manager, I'd try my best to get it covered under good will. Isn't there some law that says even wear items are covered for the 1st 12 months? But that likely has an abuse clause as well. Either way, best of luck and hopefully the parts are available.
Funkdoobiest
Buffalo
Ford Bronco Basesquanch First Edition
Was this the guy you let drive your Bronco?
Dom
Dom
Phoenix AZ
2000 Ford Expedition, 2013 Ford Fusion
Wow, that looks bad! It definitly seems like your friend screwed up.
VoltageDrop
Fidalgo Island, WA
23, 69 Bronco
I was just thinking of the same video when he mentioned the beach. His buddy thought he was throwing a sweet rooster but he was really just getting lung cancer from burnt asbestos.🤓
BlueOvalBandit
Kenneth
Anaheim, CA
Tacoma
Didn't Ford replace that other 10 mile burnt up clutch/transmission under warranty? The one they got so hot they blued the input shaft.... But that wasn't abuse...
0ne
Nate
CO
Flex
Automatic transmission for the win, 😉 sorry, not sorry 😬. That’s a lot of crud built up in that bellhousing for 4500 miles 🤔.
68 galaxie
Jax Fl
1968 galaxie /2017 f450 /2021 f150 / 2023 Wildtrak
It’s looks like the transmission seal failed got grease on the clutch plate , causing slippage and burned the clutch up. What ever you do replace all of it even the pressure plate
ColeTrain84
Cole
Minnesota
'22 Bronco Badlands
Yeah that thing is toast and was abused. I've had 3 high horsepower manuals(2 Camaro Z28's and a C5 Corvette, all highly modified) and even when the clutches finally couldn't hold the power anymore the clutches didn't look that bad. like not even close.
1970AMCAMX
Robert
Titusville, FL
F150, AMC AMX, DF Goblin
clutch is about 1000 to replace. that's not the big deal. it's the transmission that is. Ford doesn't even have the part (transmission) in stock. back ordered until end of Aug or later.
What possible reason would they give you for having to replace the transmission due to a scorched clutch? Chances of any damage other than possibly the input shaft seal are pretty slim.
mpeugeot
That would make more sense... The input shaft of the transmission shows no signs of any discoloration.
21BL2DR
JD
ohio
2021 BL 2dr, 2021 BB 4dr, 2022 BS 2dr, trifecta
yes but he hasn't driven it. I let a guy use it and while he was driving it at the beach is when the clutch failed. how can you tell it's abused? what would someone have to do to cause this kind of damage?
Uhhh…..your question is answered. Your “friend” used it alright.
Donkeygyrl
Sheri
San Francisco
Bronco on order
Yes this is real. Ford is rejecting warranty replacement of the failed clutch and transmission on my 2022 Bronco Big Bend manual transmission. Bronco has 4500 miles on it. Clutch is "burnt up" according to dealer. They claim this only happens with abusing the vehicle. My Bronco has not been abused and only driven off road at the beach.
Anyone else having transmission and Clutch issues? Did Ford reject your claim?
High rpms partial clutch engagement careless friend.
