2022 Bronco Clutch and shifting problems
21BL2DR
JD
ohio
2021 BL 2dr, 2021 BB 4dr, 2022 BS 2dr, trifecta
I guess the moral of the story is, don’t lend your Bronco to your buddy - especially if they are taking it off road.
Best advice ever written on the world wide web. We have a winner !
Boltstop
Rudy
Idaho
69 Bronco 302
Good afternoon. Can you please send over a private message with your VIN and the name/location of your local Ford dealer? I would like to look into your Bronco's situation on my end.
I'd go with this seems like the best solution
Deleted member 20624
Guest
@Ford,
I'm have a similar issue, clutch worn / failed after only 14000 miles!! Been driving manual for 30 yrs and never burnt a clutch. Have a Ford case open but warranty was refused b/c standard Ford policy "clutch is wear and tear and not covered"
I'm convinced this a defect and should be covered. Vehicle at the dealer 30 days and counting.
Ducati1098
@Ford,
You aren’t going to get any help tagging @Ford. It isn’t actually Ford.
And even @Ford Motor Company will just refer you to your nearest dealer.
If you want help, you’ll need to call someone at Ford.
