JrUnderdog
Larry
Cocoa, FL
2025 Bronco Badlands Non Sas 2023 Ford F150 Rattler
I just received my 25 BL SAS and the double honk is disengaged. Can't from factory that way. I haven't done any of the mods yet. Are all the mods/changes wiring for the 25s? Glad I found out about the change with having to remove eco to add sport
If I understand correctly, your BL double honk on exit with key was already disabled and you believe they do not come from factory that way. If that is correct the explanation is the 25 sync 4 has an option to turn of the double honk. I found it in the settings. Someone at the dealer probably turned it off. If I misunderstood then sorry for the response.
David Lott
Brenham TX
2025 Bronco Raptor
Forgive me if this has been answered. Does ForScan support the 2025 Bronco Raptor? I need to turn off the idle limiter.
SierraBronco
There's no reason it shouldn't.
As far as the idle limit, ugh. It worked on the F-150 rappy but it will not work on the 2.7L Bronco. Not sure on the Braptor.
David Lott
Brenham TX
2025 Bronco Raptor
is there a listed cheat sheet for the modules on the newer Broncos?
SierraBronco
There should be a spreadsheet at the beginning of this thread. Nothing has changed as far as I know
SierraBronco
I need to permanently disable the engine stop at idle after 30 minutes
Yeah. Me too. Let me know if you figure it out. I tried comparing to the F-150 modules but couldn’t get it to work.
SierraBronco
Hey soooooooooooo….this happened
The option to turn it on is gone. Just like the pickup. I have yet to test it.
Ford Bronco 2021+ Bronco ForScan Thread IMG_7669
SierraBronco
@David Lott I just set a timer for 33 minutes and let it idle. It works and no longer shuts off. Thanks @GooseTuned!
(He did warn that excessive idling is bad for your turbos, but I’m okay with that. I’d prefer the dogs to not be uncomfortable if I have to step out and the thing I’m stepping out for takes more than 30 minutes)
David Lott
Brenham TX
2025 Bronco Raptor
Ya my dog is more important, and it's only once a month. I found the police idle option but forscan is giving me grief saying I don't have the correct security key
SierraBronco
Once is all it takes to lose your buddy forever. I’m glad it’s gone
David Lott
Brenham TX
2025 Bronco Raptor
What module was that in? and what was it called?
I found police idle in the PCI but that did not work.
SierraBronco
I believe IPC. I used easy mode as I was trying to see if it showed anything from Winfields change to I think 8 hours. (That was the example I gave him. Didn’t confirm what was changed) I didn’t see anything different, but went ahead and disabled it. And that did the trick.
Jorvin
Jordan
Calgary
2024 Bronco 4 door
I did these Forscan mods to my 21 Wildtrak that I was getting ready for a full speaker/amps/sub upgrade:
  1. Added Rock Crawl GOAT mode (to Wildtrak). I think I have all modes available.
  2. Disabled the startling Honk!Honk! when you get out with keyfob and close the door with engine running
  3. Disabled Doo-doo-doo, doo-doo-doo, doo-doo-doo key-in ignition chime
  4. Disabled driver & passenger seatbelt-off warning chime
  5. Disabled door ajar chime (nice for camping/beach when you want power on and doors open)
  6. Tick Tock Turn Signal Volume adjusted to be much quieter
  7. Rear pod speakers input signal switched from "Speaker" to "tweeter/speaker/sub"
  8. Removed factory EQ settings for new dsp amp
  9. Moved all warning chime sounds (parking sensors, call alerts, etc) to come through the head unit's built-in speaker only, instead of also going through the main speakers (Otherwise, If you added amp(s), you would have amplified warning chimes blasting through all your speakers. At least in my case, anyway.)
How do you get the chimes to only come through the built in speaker?
