heritagesquatch
mike
miami, FL
2025 Bronco Heritage
So I just got a 2025 Heritage Edition and was super excited to use Forscan. Was able to turn off double honk, but when disabling the seatbelt chimes I’m having no luck. Does this just mean Forscan doesn’t support 2025 Bronco’s yet?
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
I couldn’t figure out the seatbelts either.
FYI: You can turn off the double honk in settings on the screen without Forscan.
I’m also having problems getting rid of the “doo-dee-doo” key in ignition chime.
heritagesquatch
mike
miami, FL
Good to know about double honk. Yeah so far chimes and Auto Start/Stop didn’t work for me on Forscan. Very frustrating. If anybody out there has a fix, please let us know
redone17
Cold Spring, NY
I noticed this in LivinItUp’s F150 that includes 2025. But, that digit is 2 in my As Built.
Disable key-in ignition chimeIPC720-02-01xx*xxxxxxx--subtract 8 from current value (if E change to 6)
je1279
Jared
Upstate NY
2025 Bronco Badlands Sasquatch
You can definitely use forscan for some things on the '25s, but certain things that worked on prior years no longer work (ex. disable auto stop/start).
redone17
Cold Spring, NY
Correct. I got a bunch of favorites to work. Global Windows Up, Bambi Mode, Powerpoint Timeout Disable, etc.
EGSquatched
Matt
Central Ohio
23 2dr Base Squatch
I’ve gotten most changes to stick on my girlfriends new 2025 except for auto start/stop, auto hold and the tire size change. Anyone have luck with these yet?
SevenT
1970 U15 Sport Edition; 2021 AMB 4 Door Badlands
Max tire size in mm in the BdyCM is 2791. Works for my 37s.
EGSquatched
Matt
Central Ohio
23 2dr Base Squatch
What year? My 23 accepted the change but the 25 isn’t, only running 33’s on the 25 so it’s not the mm.
heritagesquatch
mike
miami, FL
Would you recommend that I revert the ones I couldn’t get to work back to default settings to avoid issues later?
redone17
Cold Spring, NY
I was wondering that myself…I should take better notes. But, the two I believe I need to go back on are “Key in Ignition” and “Seat Belt Minder”
SevenT
Mine is a 21. All tire sizes in BdyCM is circumference in mm.
Mquerin
Arcadia
Bronco base 4Dr non-sas
not sure if this is the best place to write this...
I am new to forscan. i am using it on my 2022 ford bronco 2.3 auto base. it doesn't have a locker, so i wanted to do it factory, so my plan was to change the module in forscan so that it would recognize a locker on a hero switch which i bought that has the rear locker on it. I looked online and was told to change the awd module under code from
703-163-03 0000 0005 04D0
to
703-163-03 0000 0004 04C0
but instead, i changed it to
703-163-03 0000 0005 04C0
on accident.
I noticed that the locker button didn't work, so i went back into forscan and this message came up when i tried
Ford Bronco 2021+ Bronco ForScan Thread Screenshot 2025-11-22 154500
i'm not sure what I did, but now I can't go back into the module to load in the old file. can anyone help? when i click yes, it asks for the new solenoid strategy and i don't want to do that, just in case it really messes things up.
Thanks in advance!
ThunderFlash
Doug
Washington
'24 4-dr WT, '22 2-dr WT, '15 Explorer Sport, '02 F250 SD V-10
Total newb here, sorry. I read the tutorial and read endless posts on the Forscan threads. I think the name Forscan is just too close to Fortran and that was a class I'd very much rather forget...so I'm a little gun shy about it. :) Two questions,
1) Is it advisable to be on a charger when connected to the vehicle OBDII port? Getting power out to my truck is not very easy.
2) When prompted by Forscan to cycle the ignition on/off after writing to the vehicle, is that done at that exact point, or after disconnecting from the vehicle? Seems like a stupid question, but it also seems like cycling the ignition may break the connection.
Thanks in advance and sorry for asking what's probably stupid questions. I'll be absolutely sure to back up all the as built modules first thing.
