Dover157
Ben
Moriarty NM
2022 Bronco Black Diamond
I do not, but I had that same DTC recently also. I cleared it and it has not yet come back.
Mine comes back as soon as I start the vehicle and the ACM process the chimes lol. Guess I’ll have to pull all the speakers and check for loose wires, may have missed a crimp when I changed them all out for kickers.
Michael Grasso
Indianapolis
2025 Ford Bronco
I have a 2025 Badlands SAS and want to add Sport mode. Looks like the trick is to get rid of ECO.
Friend has Forscan but it won't work.
Is there a build # that he needs to update to?
Anyone do a 2025 sheet yet?
Thanks!
Mg
je1279
Jared
Upstate NY
2025 Bronco Badlands Sasquatch
I have a 2025 Badlands SAS and want two add Sport. Looks like the trick is to get rid of ECO.
Thanks!
Mg
V2.3.65 worked for me. Also, you can have all of the modes enabled if you would like. It will just not display "Rock Crawl" on the screen when you are in rock crawl mode.
Michael Grasso
Indianapolis
2025 Ford Bronco
V2.3.65 worked for me. Also, you can have all of the modes enabled if you would like. It will just not display "rock crawl" on the screen when you are in rock crawl mode.
But if you delete ECO, then the Rock Crawl shows?
je1279
Jared
Upstate NY
Yes, others have reported that the words "Rock Crawl" will re-appear on the Rock Crawl mode screen if you disable Eco mode.
Michael Grasso
Indianapolis
2025 Ford Bronco
thanks just need to find someone local!
PayHeedKU
Kansas
2025 CRV, 2000 Dodge Dakota, 2025 Bandlands (ordered)
Is there a way to disable the seatbelt chime while in motion - thinking lif the passenger temporarily unblocked to reach something? When I disabled it according to the spreadsheet it still alerts you if someone unbuckles while you are moving. Is that how its supposed to work, or have I done something wrong?
VAtruck
LOL, the truck has so many chimes and lights, my mind has tuned them all out.
bloominguez
Tom
Atlanta, GA
'22 Br BD, '22 5BW, '24 GR Corolla, '94 VFR, '04 SV
PayHeedKU
Kansas
MachingBird
Christopher
Western, NY
2015 F-150 Lariat
My 24 WildTrak still shows the flashing seatbelt minder on the dash but forscsn got rid of the chimes.
Nope. Not sure if it’s a 2025 issue or what but the seatbelt light never goes off on my display. So you’ve been able to completely shut off the chimes even while in motion?
My 24 WildTrak still shows the seatbelt minder on the dash but forscan got rid of the chimes.
  • Like
Reactions: I-W
bloominguez
Tom
Atlanta, GA
Yes, I've been able to completely shut off the seatbelt chimes while in motion. Sounds like you're asking for two different things. Turn off the chime. And turn off the light in the dash. All I know is that the chime is off, and that's enough for me. I don't mind that the reminder lamp is still there in the dash, because I'm only unbuckled when I'm still driving out of the driveway or maybe in a slow residential area, or when I come home and want to lean out to get the mail.
PayHeedKU
Kansas
Yeah that’s all I’m looking for is to get rid of the chime - don’t care about the light coming on. I was just saying the linked procedure doesn’t work because the light never goes off - see Step 3 “Wait for the seatbelt light to go out”. I can virtually guarantee its user error on my end. When I get some time I’ll mess around with it some more.
Acewizard
LUCIAN
Kentucky
2023 Bronco 4 Door 2.7 ecoboost / 2017 Mustang 5.0 GT
Using Forscan ,I added some mods that I will post the codes. I changed Driving Modes, Speakers,(rear+ sub)Below I will add the Windows (Roll down and up using the key fob), and double honk(eliminate). Below I will add the forscan spreadsheet that I made.
SkyKing
Boston, MA
'21 CG Wildtrak, E.R.A. Cobra 427 S/C
I did these Forscan mods to my 21 Wildtrak that I was getting ready for a full speaker/amps/sub upgrade:
  1. Added Rock Crawl GOAT mode (to Wildtrak). I think I have all modes available.
  2. Disabled the startling Honk!Honk! when you get out with keyfob and close the door with engine running
  3. Disabled Doo-doo-doo, doo-doo-doo, doo-doo-doo key-in ignition chime
  4. Disabled driver & passenger seatbelt-off warning chime
  5. Disabled door ajar chime (nice for camping/beach when you want power on and doors open)
  6. Tick Tock Turn Signal Volume adjusted to be much quieter
  7. Rear pod speakers input signal switched from "Speaker" to "tweeter/speaker/sub"
  8. Removed factory EQ settings for new dsp amp
  9. Moved all warning chime sounds (parking sensors, call alerts, etc) to come through the head unit's built-in speaker only, instead of also going through the main speakers (Otherwise, If you added amp(s), you would have amplified warning chimes blasting through all your speakers. At least in my case, anyway.)
