Fly
MA
Subaru Outback
What are some of the most popular forscan mods? I don’t have a windows laptop and am debating buying a used laptop plus OBD cable or just getting the 4dtech start-stop eliminator? 2022 big bend Sasquatch for reference
mpeugeot
All 8 GOAT modes
ASS defeat
Bambi Mode
Seat Belt Chime disable
Tire Size Calibration
Double Honk disable
TPMS disable
etc
snolen
stan
indiana
78 bronco
how do I get the rear fog icon on the instrument panel I turned on the rear fogs but no icon for it yet . I turned on the front fogs and have the icon when they are switched on.
Itsdchz
Clovis, CA
2021 F150 PB XLT - 2022 Bronco WildTrak
Love the Unreal theme
Looks awesome with full screen CarPlay!
Ford Bronco 2021+ Bronco ForScan Thread 09862223-CA01-4251-8AFD-E0C41E584F55
TroutMD
Gerad
Lubbock, TX
2023 Bronco
Anyone with ACC able to post their values of the C-CM from ForSCAN?
Have one wrecked in the front, it was missing. Bought a new one. Know it needs the VIN into it, I have done that, loaded the 'as built' data into it. However, when I do the calibration, it sets at 0% as I drive around and nothing changes.
Feel like there is a value that is off??
Also, bought a new HeadLamp module for my left signature headlamp, it needs 'programmed'. Any ideas? I sent a message to ForScan, they sent me a build with a headlamp configuration, but it says error. Seems like I need to laod/activate the module???
thanks!!
‘21OBX
90Bronco19
2022 bronco outer banks
You have to select it in the ipm section as well as the bcm.
sage729
Ian
Maryland
4dr Big Bend soft top, Area 51, non SAS, mid pack
Anyone know the code to change the turn signal from 3 to 6 blinks? I have a 21 Big Bend for reference. Thanks.
Tex
Cliff
San Angelo
Same here.
Tex did you get your rack programmed. I was wondering if you still wanted help?
Not yet, I've been finishing up with work and whatnot. Was actually going to get with you later today to see when you were free to meet up.
dj050894
2022 Bronco
Forscan amateur here, Question for the Forscan experts. My friend go into a minor front end accident in his Bronco, one of the headlights had to be replaced. When he first got it back from the body shop the headlights were turning on when the vehicle was off. Took it back, they fixed it, but now the headlights stay on for about 10 minutes after turning off and locking. The courtesy lamp setting in the computer is set to 0 seconds. Is this something I can fix in Forscan?
Tex
Cliff
San Angelo
Has anyone looked into disabling traction/stability control entirely with forscan?
Holding down the button for 7 seconds and verifying that advancetrak is off isn't actually disabling anything, it lessens some of the effects but it's still there.
Was thinking it would be nice to maybe just edit a goat mode so it's only disabled in the modes you really don't want it on.
Also found out that when you disable advancetrak it also conveniently disables the cruise control for you, so I'd definitely want it to be selectable rather than permanent...alternatively, some way to not disable cruise control would work if it had to be a permanent/physical mod like cutting a wire or pulling a fuse.
Trickster
Trick
Tucson, AZ
22’ Badsquatch, Lux, Cactus Gray, 1991 5.7 bronco
All 8 GOAT modes
ASS defeat
Bambi Mode
Double Honk disable
TPMS disable
etc
Would you mind sharing how to disable TPMS, or at least lower the threshold for tire pressure
Briancf
MA
23 Bronco Base, 98 Mustang GT
Has anyone had their Speedometer recalibrated through their dealership after changing wheel diameter? Or is Forscan the only option at the moment?
Just purchased a base and looking into new wheel/tire options - most of which will put me 5+MPH under actual speed. I'd like to correct it through the dealer to avoid warranty issues down the road if possible.
Will be calling dealership Monday when their Service Dept. is open and can report back if anyone else is interested.
Ducati1098
The dealership cannot do it, unless one of the technicians has forscan. The ford diagnostic tool can’t do it.
Boosty06
Richard
Odessa, Tx
2023 Black Diamond
Has anyone had this issue with forscan? I have modified several other vehicles and never seen this
"If PCM has a custom tune installed, please enter strategy/calibraton name or part number of FACTORY PCM (ex. 5L3A-12A650-AYH)"
If so, what was your fix? Thanks in advance.
