Naif
naif
sa
bronco
Is it possible to adjust the DRL brightness similar to the F150?
Ducati1098
I don’t think so, at least not that anyone has found yet.
Texasgrillchef
Gary
Dallas, Tx
Bronco Badlands, Harley Trike, Mustang
been looking... where is the link to the spreadsheet? I found it once, but can't find it again.
IS it accurate for a 2023 Badlands Lux, with Sas?
Also has anyone dug up any additional information on parameters we can change or alter? I like the auto stop, I like the double honk. Wish it would be a triple honk personally. I want to change the other items.
Thanks
Itsdchz
Clovis, CA
2021 F150 PB XLT - 2022 Bronco WildTrak
Texasgrillchef
Gary
Dallas, Tx
Itsdchz
Clovis, CA
V1Rotate
Bryan
Brevard, NC
2022 Wildtrak
Thanks I don't see anything about changing the Tire Pressure for the TPMS. I want to change the actual pressure setting of the tire before it starts giving me warnings. I know its possible, because you can do it on the Bronco Sport and for the F-150
I‘m not sure about changing the threshold value for a TPMS warning but I did go in and change the target pressure value (which will then lower the warning threshold by a linear value). Just go into the BdyCM plain english module, not the ”as built” one and change TPM Placard Front (and rear) to whatever it is you plan to run in terms of pressure. The stock value is likely 39 if you’re in a Sasquatch which nobody should ever run with 35’s. I changed mine to 30. It’ll reset the TPMS sensors but they’ll come back after you drive it for 2 minutes or so
mattm54
Matt
Katonah, NY
None
Thanks
I thought there was a google docs version but can't find that one. there is an attachment in this link https://www.bronco6g.com/forum/thre...k-sport-mode-chimes-seatbelts-and-more.28489/
should work for all broncos 2021+
BigMeatsBronco
Allan
2021 FE 2 door
Yes thos is easy, I have mine set real low like 18lbs before warnings.
