RobBob22
Rob
Georgia
2018 F250 SuperDuty
For the last several months I've been collecting data with @Gene Dios with my own personal goal of getting a lot more articulation out of my bronco. I'm a data driven person and I've been planning upgrades. Spoiler I made those upgrades, I went with Teraflex Flacons and I'll talk about those too. Suspension threads seem popular right now and considering all Badlands and Sasquatch rear coilovers are now basically scrap, I would assume that's has something to do with it. Recall: Bronco Rear Suspension
Suspension was not really on my 2024 upgrades list but a forced decision after installing the Ford Performance Winch and seeing how much the front suspension ended up sagging - at least this is how I justified the upgrade to myself and my wife. At that time I went with the pretty obvious - affordable solution Bilstein 6112's. I ran those for a year but I generally knew they would not be my long term solution. For ride height and leveling, they were great and if that's what you're looking for they're great. @Snacktime recently posted a pretty detailed thread about this suspension and Ride height. A Ride Height Focused Thread - by Snacktime What I learned is that I really wanted travel, and the Bilstein's do not give you that, so in 2025 I made a change. In fact, I didn't even really look at ride height.
I'll try to avoid the recipe blog trope of giving you a life story before I get to the secret sauce, well do that after. Way back in 2023 a Stock Suspension and Calibration thread was started by @87-Z28. It's been a few years, more suspension for the bronco has been made available since then. So below is an incomplete table of available suspension options for the Ford Bronco with compression and extended lengths - BUT - that's not all. The complete table linked just below has much more data. We're adding any information we can find, and so can you. There is a lot more information in the google doc than shown here. I really focused on this compression data, emailing manufactures or hunting it down on their websites when available or in the threads. I welcome others involvement in building this data (if you're a high level contributor I'll give you direct access to edit the file.)
Available Bronco Suspension Data
Ford Bronco The Ultimate "Travel" Guide - Bronco Suspension Data Compilation Screenshot 2025-02-25 at 7.03.32 PM
A bit about the data. I personally emailed 8 companies and requested the above information while others had this info directly on their product specifications page. Of those that I reached out to all but 1 responded with the compressed and extended lengths and total travel. ICON claimed said information was "proprietary." *ICON has since joined to conversation and confirmed their numbers.* If it didn't come directly from the manufacture, it was from measurements posted on B6G.
So, what do I think the data shows. Really I believe it boils down to a simple thing, maybe two. All of the available suspension is designed for either 1) high speed whoops and jumps or 2) maximum articulation over obstacles. Novel right. The second thing I think is shows is, how accommodating will this suspension be for 37" tires. You might also read this as; how much do we not want customers complaining to us when their 37" tires smash-in their fenders.
Take any Fox suspension for example; all versions of the Fox suspension cut almost an entire inch off the factory Badlands suspension travel up front. Why? Fox suspension has almost always been advertised as the desert runner, whoops, and jump suspension. Also, I think it's a fair point to make; anyone spending the money to upgrade to the higher end Fox Suspension is going to be running 37" tires. They're also going to sell a lot of suspension, they're arguarbly the most recognizable consumer brand in suspension, they don't want problems. I love Fox Suspension. *Edit* I think it’s valuable to add a clarifying point here, the Fox suspension uses a 1.5” bump stop, most other are using longer, so travel may not be that much less.* I've run Fox suspension and if I was looking to go fast they would be high on my list, maybe that is what you want. I'm not looking to go fast in my 2.3L, 2-door bronco. I'm looking to articulate over big rocks and keep the count of wheels on the ground to 4 as much as possible (anyone who went to AOP with me this weekend knows I'm doing a bad job at that).
There is 1 other thing I calculated from the data. This is the ratio of suspension travel to wheel travel. Wheel travel is extremely ambiguous but, If the claim was made I included it, and calculated this ratio. Why, because the average should give you an approximation of any particular brands wheel travel. It's also a check of sorts, outside of other mods (front lower control arms, etc.) you can't really extend straight on -no articulated - wheel travel beyond the limitations of the Broncos front and rear axles. Without front lower arms, and in the rear without making modifications to brake lines and the drive shaft angles you won't extend much further and this ratio is much closer to 1 based on suspension design vs. the front. As of writing the average front ratio is 1.62 and the average rear is 1.29.
So why did I go with Teraflex suspension, and why specifically did I get the max travel option for 35" tires and immediately install 37"s. The answer is calculated risk. Based on the above data I noted the Teraflex Falcon's are not any longer than ICON for front travel, and I'm not too worried about rear travel. I've seen broncs with ICONS and true 37's rub only a little. No spacers, body lift, nothing. I called Teraflex and I asked, "Will I smash my fenders", and the guy I spoke to was like, "I would prepare yourself for the possibility of smashing fenders." Not confidence inspiring, but he also said these magic words, "our 37" mid travel suspension designed for no frame or body modifications." Which was enough for me to say, cool because where I'm going we don't need crash bar mounts anyway.
Like I said, I wanted maximum articulation. If the above is not anecdotal enough to prove to myself this is what I wanted a few other minor things peaked my interest. 1) Was this thread and a similar youtube video I found of a Bronco completely flexed out with little more than lower trailing arms and the falcon suspension and 2) the somewhat complex instructions for the Teraflex suspension involving trimming of the gas tank skid to better clearance the drive shaft under articulation while having to remove and replace a control arm bolt to eliminate contact with the gas tank as well as the inclusion of brake line relocation brackets and a track bar relocation bracket; I was at minimum impressed with the level of R&D that went into development. I could also make a good case regarding cost comparison to alternate options and a respected following in the Jeep world.
I did all this digging because I was also kicking around the idea of installed the Rock Krawler 4-link conversion, and if you asked me in December I was 100% going to do this install, and its still an option for future me. However, in all my reading up of this modification it almost seems like for every person that loves it another at least partially regrets it, or have found they have needed to make several other compromises and upgrades to accommodate this kit. @Bird Dog Off Road @coffeetwitch @Mdsuits have all commented on some of the challenges with the 4-link conversion. I will note @SierraBronco does get extreme - almost unreal - flex out of this setup particularly while paired with portals.
With all that I ultimately went for the full Rock Jock rear trailing arms and track bar. Also, while I was originally running an Apex Designs adjustable front sway bar this design ultimately made contact with the spindle after going with the longer front Falcon suspension so I've offically joined the no-sway bar club, and seeings as I'm a 2-door with no intent of putting a massive roof on top of my bronco, I don't think I'll be going back. The Teraflex suspension has settings all the way from plush to stiff, and I find running anything 2.6-3 on the settings seems to be pretty solid for on road manners.
Prior to the Teraflex and Rock Jock rear trailing arms and track bar, from an articulated front and rear lift by a fork lift I measured 16" front (Sway-bar engaged) and 18.5" rear, (ground to tire) but now measure 24.5" and 27" respectively gaining 8.5" of articulated travel front and rear. The numbers I measured are very in line with what I have seen for modifications including the rock Krawler kit. In off-roading I have not observed any signs of gas tank or skid contact. Maybe a small amount of fender contact on the rear passenger heard while off-road, but no signs yet . Pictures below, including a picture of me getting almost too sideways at AOP in Tennessee.
I hope the data is found to be useful, and others find opportunities to build on it. I excluded very custom options like ORI STX struts, and I'm sure I missed many options, feel free to include or maybe we'll search them out.
Ford Bronco The Ultimate "Travel" Guide - Bronco Suspension Data Compilation Screenshot 2025-02-25 at 9.43.34 PM
Ford Bronco The Ultimate "Travel" Guide - Bronco Suspension Data Compilation Screenshot 2025-02-25 at 9.41.26 PM
Ford Bronco The Ultimate "Travel" Guide - Bronco Suspension Data Compilation Screenshot 2025-02-25 at 9.39.39 PM
Bird Dog Off Road
Jody
Phoenix, AZ
www.youtube.com
There is another system from Vasher designs that look promising and it’s completely bolt on. It’s a 3 link rear suspension kit. I don’t know anyone using it yet, but the design is intriguing to say the least.
SierraBronco
Awesome data compilation sir. Will be very useful for those looking in to upgrading their suspension!
Definitely recommend boxing in the upper link frame mounts with the RK 4 link setup. A bunch of people have broken theirs with the stock setup-the lateral movement certainly won’t make things any easier. And as you’ve probably seen on my other posts this might also prevent you from running the RockJock rear swaybar as intended for factory bronco setup. A member on the forum recently shared pictures of his where everything was lined up properly, but it was on a forklift. Might be different when actually wheeling and your axle moves three inches to the side while articulated and off-camber. Still happy with the setup though. 👊🏼
RobBob22
RobBob22
Rob
Georgia
2018 F250 SuperDuty
I’ve seen their long travel kit, is that that same thing? Can probably add a whole section for long travel designs, not too many options there.
RobBob22
RobBob22
Rob
Georgia
2018 F250 SuperDuty
Your boxing recommendation, is that only early 21s or do later version also need the reinforcements?
I’m still very much a fan of the RK 4-link but it certainly needs to be understood by those going down that road it’s a serious undertaking. Everyone I’ve talked to loves the on-road handling and eliminated rear steer, which is great, but also finding that on-road handling was the most significant complement for a system designed for off-road handling was I guess concerning in my eyes as well.
SierraBronco
It does seem like the 21’s were the most affected, but the mounts are still pretty thin on our 2022 so it just made sense to me to try avoiding the problem. Much easier to fix when you’re already dropping everything anyway rather than finding it on the trail is how I looked at it.
GreyZ
Gulf South Louisiana
Turbo 350z, Bronco Badlands, Xterra
4wp/ProComp17.687524.31256.62516.7526.87510.125Yes(thread)No2.5NoAluminum
Figured this one could be added.
These ratios are interesting. Without changing LCA the motion ratios stay the same. ~1.65 front and ~1.12 in the rear.
I bet these discrepancies come from tested wheel travel but theoretical shock travel not including bump stops.
CatMonkey
Lafayette LA
2023 Bronco, 2012 Shelby GT500, 2021 Shelby GT500
Wouldn't these raw travel numbers in your table be more theoretical suspension data than real world possibility? In other words, wouldn't the stock geometry be the limiting factor for wheel, or actual tire travel within the IFS over the shock limits. Once a shock is installed on the vehicle, potential wheel/tire travel may be quite a bit different than what the actual suspension components allow given restraints in moving components and physical obstacles and/or limitations in joints and bushings. You mention the Fox shocks exclusion because they have less travel than a stock shock, but perhaps Fox engineers took real world limitations into account in their design. Anyone that's changed struts probably knows you're only doing to get so much extension out of the lower control arm, especially while everything is still bolted together, not unbolted to get more clearance for an install. Likewise, a tire will limit how much uptravel is possible until the fender and tire make contact with the fender or the bump stop makes contact.
In reading Accutune's article and videos on the Fox PE and King shocks, it would seem Fox's maximum length for the Performance Elite is at the limit of a safe CV joint angle for the axle, since their tune mod includes shimming (limiting) for maximum extension of the King shock to basically the same measurement as Fox. Accutune's full extension measurements for the Fox and King front struts differ from your data at 24.26" and 24.6", respectively. Unless you're dropping the front differential, longer shock length may not be in your best interest, if it's even achievable. There's only so much droop you get of of the front geometry with stock suspension components. I've also gleamed from Accutune's posts that posted data like you have above is only comparable if all the shocks in the mix are measured at the same reference points. No independent source has compiled that data to make it a comparison of apples to apples.
I edited your pics to illustrate what I'm seeing as your wheel travel in what I'm taking to be the more extreme angles on the IFS front end you're experiencing by using the level front bumper as a reference point, and it's a whole lot less than 10". Assuming you have 37" tires the sidewall height is about 10", so I think I'm being generous saying you have 4" of "tire" travel.
Ford Bronco The Ultimate "Travel" Guide - Bronco Suspension Data Compilation Shock travel
Ford Bronco The Ultimate "Travel" Guide - Bronco Suspension Data Compilation shock travel 2
I'm a lot less concerned about the rear travel as what I see as over extension on the rear shocks. I'm not sure I'd want that much free travel out of my suspension especially on a steep descent. It just seems to me that to get 10" of wheel travel out of the IFS in a Bronco with 35" or larger tires would take some rather substantial geometry changes to the front suspension to pull it off. The long-travel kits I see address this in some way, shape or form, which is more involved than a bolting on another damper. Maybe I'm missing something, but can anyone explain what part of this anology is wrong or doesn't make sense?
Has anyone taken actual measurements on maximum and minimum "shock length" specifications on a Bronco at full droop and compression without a shock in place and a 35" tire bolted on the axle? With stock and aftermarket UCAs? It would seem to me to be a more critical dimension in choosing a shock package, than shock travel you can't effectively use.
Rkgzx9leftcoast
Robert
Scottsdale AZ
Jeep JL
Great write up. Thanks for the input.
I really like the terraflex seems like it is described as having a really nice ride compromise. What I am on the fence about is the location of the rear bypass valves and having to run a big negative offset wheel. I have the 6100s now and am not in love with them.
The other company I would lean toward is the Carli king suspension. Sage Carli usually kills it on his tuning compromise.
TeocaliMG
Plymouth Michigan
Geometry could help, but I think the biggest problem is shock/spring tuning. Most folks chase lift and that almost always comes with stiffer springs, or more preload, at the detriment to flex as it gets harder and harder to reach jounce on the loaded tire in "Static" conditions. The stock set up actually flexes alright. I would be surprised if any aftermarket companies that added lift also had softer than OEM springs. I am not a shock expert, but presumably softer springs would require significantly more damping to avoid bottoming out on the same dynamic hits, as well as more preload to hold ride height and more preload adjustment to support the same range of GVW's. If I were building a rig that I really wanted to shine in the rocks and cared less about G-out protection, or high payload capacity, i'd run the softest springs I could get that allow adjustment to my target ride height.
Loesch
PA
2016 F150
You guys are really stretching the excuse to the wife why you're spending $4g on suspension. haha. Thanks for sharing the data you compiled. ICON shouldn't even be a consideration, probably should be removed from the list then if they refuse to provide details about the product they sell. I know they are off my list now.
AccuTune Offroad
2021 Sasquatch 4 Door, Jeep JLUR, Tacoma
Definitely keeping an eye on this one. Happy to help answer any questions if we can. :cool:
popo_patty
Caleb
Sacramento
2021 Bronco/1996 Jeep XJ/1957 FC-150
Yea they refused me data as well when I did my video awhile ago. It’s also interesting that they have the most hate amongst shock tuners, and they have a high amount of warranty repairs.
CitrusBronco
Everglades
Citrus county, FL
Everglades
Looking good on that flex.
So you have 37” in those pics, what offset are the wheels?
Oldhippie
Barry
Santa Cruz, Calif.
I am no suspension expert by any means but it seems to me there is a hard travel limit (into the fender to pulling the CV apart) on the bronco front suspension? With 37”s about all ya can get is a little over an inch (-1” up travel/+2” down travel) over stock (some extra up with a body lift and a little more down with a diff drop). Fox is a little conservative and Icon pushes it hard…I really don’t know how you folks are getting around these limits?
