Winch recommendations for capable bumper
Victorsen
Vic
Maryland
Ford bronco
Looking for a recommendation between the IAG heavy duty winch mount with an open road 12 k synthetic winch and the RC hidden winch mount which seems to have their winch included for $759. Not sure if the RC version is steel or synthetic. I want to go synthetic. I have a capable bumper and really trying to do the easiest install without having to make any major modifications and not reduce my clearance. Understand that some components will need to be relocated.
https://www.roughcountry.com/product/configurable/hidden-winch-mount-51065#2921=6653
https://iagoffroad.com/iag-i-line-h...-for-2021-ford-bronco-modular-capable-bumper-
Pokey_Cacti
Dan
Prescott, AZ
2024 2-dr Black Diamond
You can replace a steel cable with a synthetic rope...
T800
Rick
Riverside, CA
OBX SAS Avalanche Gray
I have a Warn Zeon 10 on my Jeep. I won't buy anything other than Warn.
Pokey_Cacti
Dan
Prescott, AZ
I've got a '24 Black DIamond with a capable bumper, my issue with front mounted winches is I've replace my D-rings with a Blue Ox tow point so we can tow the Bronco behind our RV. We also have a TriPro front bumper camera up in front. Sorry for a potential hijack, but I'm interested in what Victorsen comes up with & uses...
3People1Body
Christopher
West Virginia
Wildtrak, F150 and Taurus.
Oldhippie
Barry
Santa Cruz, Calif.
I am not a fan of any of the bumper add on kits…I think a proper winch bumper with frame reinforcing is the proper way to mount a winch to a bronco…I was happy to get the plastic bumpers and replace them with proper aftermarket ones…but lots of folks get away with the kits…party on!
OffroadCamper
Richard
San Diego, Ca
F150 Sport 4x4 5.0L 3.73 eLocker...totaled, Mazda 3 ST, Sienna SE
Anyone have experience installing and using an IAG with Badlands Apex 12k synthetic?
Thanks to OP Victorsen for thread.
Love to hear more from anyone.
This is my current plan.
IAG said Badlands Apex 12k syn should fit. All Warns do fit. Reseach says some trimming, spacers might be needed? We shall see.
I had ADD stealth on F150 but trying to save the $5000 in parts, relocation kits and labor this time.
Should be good enough for me. Only winch a Jeep or Ram maybe once year. Usually they are winching/pulling me. Group effort.
Thanks in advance. Will report anyt future findings.
https://www.harborfreight.com/12000-lb-winch-with-synthetic-rope-and-wireless-remote-56385.html
https://www.iagoffroad.com/products...-2021-ford-bronco-modular-capable-bumper-only
EvilJim1971
Jemison Al, 35085, USA
www.instagram.com
2023 Bronco Heritage Edition
Looks to be the same mount as the Buckle Up Off-road mount.
Originally I ran that with a 12k Badland Apex.
Had to trim 2 plastic trim pieces on the bumper.
HighVelocity
Big Sky Country
Pinto
I've been pretty pleased with my JCR mount + Superwinch 10k.
Only a couple pulls so far, but I also flat-tow it connecting to the d-ring holes.
A frame horn reinforcement is usually advised and something if I were doing it over, I would add just for peace-of-mind.
GI_Jo_Nathan
Jonathan
That RC winch is synthetic. Just a heads up most all winches with the S on the end will be synthetic. Obviously I would verify before purchasing, but just for when you're looking around and comparing.
Pretty much all of them are going to interfere with that I believe. Your best bet may be the "hidden" under bumper option like posted above.
I've been looking for the same type thing. While looking at options at SuperCel East 2026, this seemed like a great option.
https://turnoffroad.com/products/2021-ford-bronco-oem-modular-bumper-raptor-winch-plate
It sat about right for my use but I haven't bought it yet.
I purchased that one a couple years ago and decided I really didn't like it half way through the install. It completely blocks the intercooler, and because it's in front of the bumper it just sticks out way too far and is a little goofy.
jjack50
Jack
Temple, NH
2013 VW Jetta TDI, 2016 F350 4WD Crew Cab
To be clear, it's the 'in'capable bumper.
The JCR winch plate has instructions for using it with the Capable bumper with minimal plastic trimming. Also there are a few companies that sell frame horn reinforcement kits. I would recommend using one of those with a bumper mounted winch.
OffroadCamper
Richard
San Diego, Ca
GI_Jo_Nathan
Jonathan
OK great feedback.
So will call ADD now but this seems like best option so far:
https://www.addictivedesertdesigns....ts/bronco-frame-horn-gusset-reinforcement-kit
Maybe not maybe DV8 version?
Mixed research on fitment?
Probably one of the better ones that's available currently. Install is okay, I know me and a few others have had to chop up the bracket for the factory nut plate because it won't reach when it goes over the add bracket. Will make more sense once you're installing. It's not able to go back like stock in my experience. I would say the LOD is probably stronger, but a giant pain to install with Drilling several holes. But then result is 8 bolts holding it to the frame versus two on the ADD. I always preferred the metaltech, but at least a hundred more dollars and doesn't look like it's currently available.
