Winch recommendations for capable bumper?
mdfilip
New Hampshire
20 Shelby GT350, 22 Bronco BL, 29 Ford Roadster
Any recommendations on a winch for someone fairly new at least new to using a winch? I just purchased Buckle up off-road winch bracket for my capable bumper.
BigBend530
Dominic
Oroville, CA
2022 Ford Bronco 2Dr.
You're likely going to get a lot of varying opinions but it seems the Badlands 12k from HF and the Warn VR Evo are some of the more popular options. I personally did the 10k Warn VR Evo with synthetic rope/cable in a JCR winch mount with capable bumper.
Another thing to consider (new to winching or not) would be adding frame horn reinforcements when you go to mount up the winch bracket. Do you need them? Not necessarily. Will you wish you had done them when you bend the frame horns and your bumper sits awkward? Every time you look at it.
mdfilip
mdfilip
New Hampshire
I was looking at the Badlands winch but I know Warn is a well known with reliable products and I don't mind spending a little extra to get something that will last.
Where can I get frame horn reinforcements? If I have it apart I probably should put them on.
BigBend530
Dominic
Oroville, CA
Couple things to remember with Warn are they are not all created equal in terms of where they are made and assembled. The VR Evo line are not made in USA.
Best to search on here or Google, etc. for a good list of options as I won't be able to name most of the offroad shops that make them. Addictive Desert Designs, Metal tech and LOD Off Road are some examples.
GI_Jo_Nathan
Jonathan
I second doing frame support brackets while you are there. The LOD's seem to be the cheapest, but are a pain to install since you have to drill holes in your frame, and some people have to modify them. The A.D.D.'s seem pretty good and only cost a little bit more. And Metaltech is arguably the best but cost a good bit more.
MNBigfoot
MN
The Ford Performance Warn winch kit, dropped in price from $2500ish to $1050, it's 15% off (first $1000) so $900 some have been getting 20% ($850), it includes the frame horn supports and a $1300 Warn Zeon 10s winch. Plus you can use your Ford points if you have any.
2021-2024 FORD PERFORMANCE PARTS BY WARN® BRONCO WINCH KIT | Accessories.Ford.com
Winch that's included (made in USA):
ZEON 10-S Winch | WARN Industries
A few guys bought the kit just for the winch and few guys are looking at purchasing the mount.
mdfilip
mdfilip
New Hampshire
Thanks! I just ordered the Ford Performance Warn Winch Kit... if you use the REDEEM924 code that shows on the site you get 15% off but if you use SHOP924 that popped up on my Honey app you get 20%.... so I paid $840 shipped to my dealer and I also get 8400 points .. not a bad deal.
MNBigfoot
MN
RagnarKon 's video of small mod for the capable bumper
Ford Performance WARN winch on capable bumper — Yes it's possible! | Bronco6G - 2021+ Ford Bronco & Bronco Raptor Forum, News, Blog & Owners Community
Props to '21OBX who discovered the deal
mdfilip
mdfilip
New Hampshire
This kit says required bracketry and hardware ... it does not come with the actual mount does it?
Badlands Traveler
Mojave Desert
Ford F150 XTL 4x4 2019. Bronco Badlands Sasquatch
I put a Badland winch on on my Bronco, and I’m very happy with it!
MNBigfoot
MN
I believe it comes with everything, the box weighed 190#, the winch weigh's roughly 80#.
mdfilip
mdfilip
New Hampshire
Ya I'm reading the instructions and it looks like it comes with everything same as what is in RagnarKon 's video ! I will just have to fab some mount for the sensors and camera on mine. I purchased the Buckle up off-road mount already that was almost $500 and I purchased that because it has all the brackets and wiring to relocate camera and sensors. I will figure something out if I can save that much money.
Bschurr
NY
Just use the Warn winch that comes with the kit and sell the mount and other components that you won’t use for $500 to recover the Buckle Up mount you bought - duh…
BTW - the kit comes with 2 fairleads too!
mdfilip
mdfilip
New Hampshire
Anyone want a Ford Performance mount :)?
The buckle up mount sits a few inches higher which I assume give better approach angle but my OCD hates that the winch covers some of the BRONCO lettering :wink:... looks like the Ford mount sits below the letters. I know it's stupid I need to get over it.
HighVelocity
Big Sky Country
Pinto
Not anymore.
I've burned up 4 of them in the last 10 years.
I'm currently experimenting with a Superwinch on a JCR mount on my Bronco. Haven't had it long and used it enough to give a real opinion though.
I replaced one of the Warns on the F550 with a Sherpa 4x4 and so far, it's performed well.
The F350 got a Comeup that has also outperformed any of the Warns.
There is someone else in the crew who blew up a Warn and replaced it with a Badlands and seems happy so far.
