Wheel help with new width offset please
sean425
sean
princeton nj
2022 bronco
I currently have the stock SAS wheels with the Goodyear territory’s. I’m switching to Toyo Open Country RT Pro’s 35x12.5r17. I’m also switching to wheels that are 17x8 with a +55 offset. So compared to the SAS wheels which are 17x8.5 with a +30 offset I figured I’d need 1” spacers…but now I’m wondering with the new wheel also being .5” narrower will I need a 1.5” spacer? Thoughts? Thanks
Squatch
I would recommend against the +55 wheels.
The width of the wheel is going to affect how the tire width is expressed as the contact patch. If it were wider, then you might want thicker spacers or a wheel with "less" offset.
sean425
sean
princeton nj
2022 bronco
I not as concerned with the width of the wheel with the tire, 8” is within the recommended width from Toyo for that tire. I’m more concerned with rubbing and keeping the geometry as close as I can to the +30 wheels and avoid any rubbing…+55 is about an inch difference so I thought it should be pretty close
23OBX2.7
AB Canada
2023 Bronco
What 17" with +55 did you find?
sean425
sean
princeton nj
2022 bronco
I really like these in the pictures and video, they have an old school look but are still ford parts…im not huge on aftermarket stuff. I like the 2nd ones in the video below as well which are SAS wheel specs but they are going to be everywhere in a few months as they’re an option on the 2026’s…the 12 hole ones I’ve never really seen.
Ford Bronco Wheel help with new width offset please IMG_0579
Ford Bronco Wheel help with new width offset please IMG_2410
sean425
sean
princeton nj
2022 bronco
Ooo and you can get a set of 5 from ford for under $600 sent to a dealer by you for free…not bad
Oldhippie
Barry
Santa Cruz, Calif.
Wheel width won’t matter…offset will…I don’t understand not getting wheels with proper offset so ya don’t have to run spacers…but you do you…
sean425
sean
princeton nj
2022 bronco
Because I like those wheels and they don’t come in a +30 but I can buy high quality 1” spacers that will make them essentially +30.
TheI3lindMan
Daniel
US
2024 Ford Bronco
If anything I would go more negative then positive. + means it will sit inside your wheel liner more not stick out farther. See if they have a 0mm offset or between that and the 30 of the stock. Anything more then 30 you may run into rubbing issues.
PWillette
Parrie
Maine
At +55 you're going to be extremely close to rubbing the UCAs running a 12.5" wide tire no matter the width of the wheel. A 1" spacer will get you close to the SAS OEM wheels (+30)...no need to go 1.5" unless you want a bit more poke.
Wolfgang VTS
Terry
East Tennessee
2025 Bronco Base, 2021 Ford Ranger, 2022 Ford Bronco Sport
I have found this site to be invaluable when thinking about upgrading wheels or tires. There is even an offset calculator as well.
Tire Size Calculator
ZEN50
Zenon
Muskegon,MI
2017 Mustang GT/ 86 GT, Capri & Turbo Coupe/Bronco
Just had the Bronze version installed on my 23 Badlands sasquatch on the stock goodyear tires a few days ago. With this offset & width it pulled the tire inward about an 1"/1.5" approx. currently not rubbing on anything but front control arm is close. Was thinking to get 1.5" spacers and call it good.
Bronco 2021-2023 Sinister Bronze 17"x8.0" Wheel Kit | Accessories | Ford.com
Spare tire/wheel combo will not mount back up, tire is hitting the body, needs to be spaced out.
sean425
sean
princeton nj
2022 bronco
Zen50…thank you! Awesome info, let me know what spacers you wind up using and how you like them and what you do with the spare. Enjoy the new wheels!
