- First Name
- Dave
- Joined
- May 3, 2023
- Threads
- 1
- Messages
- 780
- Reaction score
- 1,504
- Location
- Southern MN
- Vehicle(s)
- A passel of Fords and a Jeep JL Rubi
- Your Bronco Model
- Undecided
These aren't BMWs.Easy fix.
Stop using your turn signals!![]()
True, but in the Dallas/Ft Worth area, nobody uses them, lolThese aren't BMWs.
The solution has been provided by Ford Special Service Message (SSM) 53238 issued December 17, 2024. Refer to post #28 in this thread.It's quite frustrating, but I'm hesitant to bring it to the dealership until there's a solid solution provided by HQ.
Thanks. I'll make an appointment with my dealership in a couple of weeks. The Holidays aren't a good time to schedule work.
This is the “fix” they did on mine before the SSM came out- helped a little but didn’t fix.The solution has been provided by Ford Special Service Message (SSM) 53238 issued December 17, 2024. Refer to post #28 in this thread.
Just tell the service writer at your dealership about it.
This isn't quite right, maybe? The problem isn't momentary or brief. Once it switches itself over, the left signal continues until deselected. That bulletin seems to describe something slightly different.
It’s the same thing. Whether it does a momentary blink, or gets stuck the opposite way, the cause is the same.This isn't quite right, maybe? The problem isn't momentary or brief. Once it switches itself over, the left signal continues until deselected. That bulletin seems to describe something slightly different.
@Ducati1098 If you have a moment, would you mind confirming the replacement part number(s) for this SSM? I see 13K359, but that feels like only a partial part number. I have had a less than desirable experience trying to get this repaired at the dealer, and as long as it's not ridiculously expensive I am considering just fixit it myself out of pocket.
Yes, 13K359 is just the base part number.@Ducati1098 If you have a moment, would you mind confirming the replacement part number(s) for this SSM? I see 13K359, but that feels like only a partial part number. I have had a less than desirable experience trying to get this repaired at the dealer, and as long as it's not ridiculously expensive I am considering just fixit it myself out of pocket.
Really appreciate it! Right now looks like ~$54 from an online ford dealer. For this price, it's not worth the brain damage of trying to get this repaired through the dealer. Thank you!Yes, 13K359 is just the base part number.
The most current part number is R2DZ-13K359-AA
MSRP is ~$93, but I'm sure you can find it cheaper online.
