Weird turn signal issue
Mer1in20
TJ
NY
Chevy Silverado
Just got my bronco last week. When i use the right turn signal, its really fast and the front two blinkers flash but the back right doesnt. The left tuen signal acts as it should . I know usually this means the bulb is bad but i literally just got it and ive also never heard of the front blinkers flashing at the same time either. Any ideas before i being it in?
Headsong
Probably loose. Good luck taking it apart. I recommend that you find @ORACLE Lighting video on their new taillights.
StoicAF
Kyle
texas
2022 Bronco
Mine does this as well. There’s a known headlight issu. Not sure if ford knows the cause. A ford rep here took my info and opened a ticket for me.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi there! Will you send us a message with your VIN and your local Ford dealer? I can look into things on my end.
mrbrenan
Brenan
EL Dorado Hills, CA
2022 Ford Bronco Badlands
My turn signals just won't turn off unless I toggle driver "down" to passenger "up" and then back to the driver side "down" - or vice versa. Really strange.
I just have to toggle it up and down before eventually the turn signal will go off. It's pretty annoying.
Ford Motor Company
Dearborn
Hi there – send a message to us with your VIN and approximate mileage. I’ll look into this for you. Thanks!
whitebronco
Joel
Orange County
VW touareg Sport
Had the same issue with headlights after three visits to the dealership they replaced the lighting module. Check to see when blinker is on if your headlights flicker. For me it started off with a slight flicker than eventually headlights would completely turn off and won't turn back on.
Awollaber
Ashley
Remsen
2023 bronco
I am currently having this issue and have had it since the week after I got my 2023. Did you get this figured out? I will be calling the dealership soon to see about bringing it in but wasn’t sure if anyone has had this issue and had it fixed.
Ford Motor Company
Dearborn
Good afternoon, Ashley! I would be glad to help you out with this turn signal concern if you'd like. Just shoot us a direct message with your VIN and dealer name/location, and I'll get right on it. To send a DM, just click on our username and select "Start Conversation". Thank you!
nathanjcoleman
Nate
Missouri
2022 Mach 1 Mustang, Ram 2500
Hello, I am having this same issue and have since it was new, the problem just happened rarely at first but now it is all the time. 2023 Bronco.
Ducati1098
