Turn Signal Issue
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
My 21 Bronco does it too. How do I contact Ford with my information?
Good morning, Pete! I would be glad to help you out with this turn signal concern should you need further assistance. Just shoot us a direct message with your VIN and dealer name/location, and I'll get right on it. To send a private message, just click on our username and select "Start Conversation". Thank you!
Kiowa
suburban, clk convertible
Same issue. Ford, what do I need to tell my dealer to check?
Kiowa
Has anyone had a successful diagnosis for this issue? For the first time I tried to DM Ford and received a stock "check with your factory-trained dealer" response. After they replaced my cracked airbag cover on the steering wheel with another one that cracked driving off of the lot, I don't feel the need to go to a dealer only to waste my time.
josh1121
Josh
Riverside, CA
Nissan Titan XD Diesel 4x4, LandRover Defender 110
I have the same issue. Taking mine in to have a look at my popping and creaking hard top, I will ask them about this also.
Ford Motor Company
Dearborn
Good morning, Josh! I would be glad to help you out with this turn signal concern should you need further assistance. Just shoot us a direct message with your VIN and dealer name/location, and I'll get right on it. To send a direct message, just click on our username and select "Send Direct Message". Thank you!
SteinerStrength
Spokane, WA
2021 Bronco First Edition and 2023 Bronco
Had the same issue. Ford replaced something in my steering column. Issue came back. I am filing safety complaints with the NHTSA. Apparently recalls are only initiated by Ford if there are complaints made through the NHTSA. Was told that this signal issue could be a safety issue due to oncoming or following traffic expecting a driver to turn due to the signal being on.
https://www.nhtsa.gov/
BrophyG
Greg
BC
2023 Bronco
I'm having issues doing this. It won't allow me to direct message- how can I reach out to you FMC?
Ducati1098
huey
kevin
Ontario & Kentucky
VW GTI VW EOS GMC Envoy Badlands Bronco
I had the repair done - still have the issue
I am learning to live with it.......but it drives me nuts
Will go back in one more time before the factory warranty is gone, but i have low expectations
Ducati1098
They don't all do this, so there must be some that are good and some that are bad?
I have no idea if Ford even changed anything on the switch, or they're just replacing them with the same old one.
I would keep bringing it back until it doesn't do it anymore.
Gump
IL
2022 Bronco Badlands Advanced, Squatched
I don’t have anything to add, except that I’m glad I’m not the only one who has experienced this. I have a 2022 Badlands Sasquatch.
BroncoDymond88
New Jersey
'23 Bronco
This has been an unfixed issue across every model year since the first ones rolled off the line.
Nibroc99
Corbin
Rochester, MA, USA
www.corbonthecob.com
2022 Wildtrak: The WildeBeast
Still an issue with my '22 wildtrak with lux. Does it on most 90 degree turns in the city.
CalvinT
Calvin
Phoenix, AZ
I think there's a design issue with the switch. I had the same problem. Dealer followed the SSM and it got better. Before it happened all the time. Now it's just every once and a while. I can live with that.
