Turn Signal Lever Problem
HanksBronco
Lee
So, when I hit the turn signal lever to the right, complete the right turn, then turn the steering wheel back to the left, the lever sometimes moves back to the left turn position. And no I’m not hitting it with my hand. It sometimes happens to my wife when she drives it too. Annoying! Anyone have this issue? Merry Christmas from Texas!
I've had the same issue, took it back to the dealership. After 2 days it was fixed, the tech advised that it was a common problem with the Bronco.
jensht
Germany
2023 Ford Bronco
Ford has a service bulletin out on how to repair this. I had my blinker lever replaced about half a year ago and haven't had this problem since.
SSM 53238
Some 2021-2024 Bronco vehicles may exhibit the opposite turn signal direction flashing briefly once a turn is completed. This may be due to the steering column multifunction switch. To correct the concern, replace the steering column multifunction switch. Refer to the Workshop Manual (WSM), Section 211-05. For claiming, use causal part 13K359 and applicable labor operations in Section 10 of the Service Labor Time Standards (SLTS) Manual. If labor times are not available, claim M-time.
