Turn OffRoad Heat Extraction Hood
Kilo
Georgetown
2022 Ford Bronco
Have you seen the NEW heat extraction hood by @Turn Offroad 👀
This thing is a beast and it doesn’t just look good. It does what it’s intended to do! At a glance it changes the look of the Bronco in a pretty aggressive way, but the real purpose is functional. Under the hood of these trucks, especially once you start adding weight, tuning, or just dealing with Texas heat, temperatures can climb fast. This hood is designed to give that heat somewhere to go instead of letting it sit and soak everything around it.
What stands out is how it manages airflow. Instead of just being cosmetic vents, the extraction points are positioned to actually pull hot air up and out while you’re moving, helping reduce engine bay temps and potentially taking some stress off components that don’t love constant heat exposure. It’s one of those things you may not immediately “feel” like horsepower, but over time it plays into reliability and consistency, especially if you’re pushing the vehicle or sitting in traffic on a hot day.
There’s also something to be said about how it fits into the overall build of a Bronco. It doesn’t feel out of place or overly flashy. It leans into that rugged, purpose built style that makes sense for the platform. It looks like it belongs there, like something Ford could’ve offered from the factory if they went a little more aggressive with cooling and design.
Another thing that sets them apart is their price point! The Turn Offroad heat extraction hood comes in right around $1,199, which puts it in a really competitive spot compared to similar fiberglass heat extractor hoods that typically land closer to the $1,250 range and can climb well beyond that depending on finishes and options. When you start looking at the broader market, you’ll find cheaper options, but they often cut corners in fitment or design, and on the higher end you’re paying a premium that doesn’t always translate into noticeably better function. This one kind of sits in that middle ground where it feels accessible without feeling “cheap,” and that balance is what makes it stand out.
What are your thoughts?
Ford Bronco Turn OffRoad Heat Extraction Hood A4BD8ACF-4A59-4BCF-A23D-D9DF5211F881
Ford Bronco Turn OffRoad Heat Extraction Hood IMG_1883
Smocaine
DFW, TX
Cervelo Caledonia
I like the idea, but the bulge (giggity) and vent shapes look like they belong more on an F150 or Mustang with a rounded nose.
Something with vents but more OEM lines might grab me. I don't have enough motor to be power bulging.
Kilo
Kilo
Georgetown
2022 Ford Bronco
I have had the ADV hood for about 4 years, looks similar. Still get the comments about water getting on the engine. I still roll my eyes 😂
That looks so good! How are you liking it now that you’ve had it installed for 4 years? Looks amazing!
Baja Bronco
2Sun AZ
22 Ford Bronco, 20 Ford Raptor
Thanks. Main reason is that I love louvers. Has held up very well, no complaints. Liked it better than the ram air hoods.
Kilo
Kilo
Georgetown
2022 Ford Bronco
It’s not for everyone and there are a few different aftermarket hoods out there that don’t have such an aggressive look. Or as you mentioned a bulge lol
Kilo
Kilo
Georgetown
2022 Ford Bronco
23OBX2.7
AB Canada
2023 Bronco
No downside with rain tray twin turbos generate massive heat.
