SierraBronco
SierraBronco
2022 Bronco
Also probably a whole lot cheaper doing it all at once rather than one thing at a time.
Smart move, and can't wait to see the results.
Makes sense to me too. I know I know-I didn’t go crazy on lighting first. And then a puck lift. And then stuff 37’s and some tierod braces on there. Gotta earn an actual build by doing other things first I guess. And then some “jeep eater stickers.” Heck-I don’t own a single piece of Ford or Bronco branded clothing! The heck kind of owner am I anyway?!?
SierraBronco
SierraBronco
2022 Bronco
100% people forget that no matter how fast or how many CFMs their pump can handle, they are still limited by the actual valve stems of the tires.
I’m going to do some testing when the compressor is installed to see how effective the APEX high-flow chuck is. Not sure I’m completely in love with it as screwing it on is a bit of a pain with the beadlocks…
Red Sox 4Life
Yucaipa, CA
Corvette, Lexus GS350, Highlander
This will be a great setup, my only suggestion is the Swaybar out of a Badlands, on our WT I hooked it up to #1 switch...The best part is you can use it at any speed, any mode. highly recommend.
That's a great idea! What did that run?
SierraBronco
SierraBronco
2022 Bronco
Just got back from a full day of wheeling and had quite the compliment from a Rubicon owner on 37’s-“the way your Bronco is making everything look so easy is really making me jealous. It’s going to be ridiculous after the build is done.”
I do attribute a lot of that to the beadlocks running 10 psi as I had great traction where they struggled a little. And maybe a teensy bit of line choice.
SierraBronco
SierraBronco
2022 Bronco
Dude. This guy got that swaybar for something like $100. I’m definitely doing this if I find a swaybar for cheap. The ride has improved with the Boss links but it would be cool to get that last little bit of articulation from the electronic swaybar
nolimits
22 Explorer ST | 23 Challenger SP 1320
Build faster, we need more Bronco porn, lol.
Seriously great job. Looking forward to the rest of your journey.
SierraBronco
SierraBronco
2022 Bronco
I’m waiting for parts as quickly as I can! 😂
Midnight_Blue
Jeremiah
Los Angeles
The more capable the rig, the further away you can get from people and the less evidence of people you’ll see.
Looks like you pulled off to the side of the highway.
Ford Bronco SierraBronco's WildTrak Build IMG_8005
billyum
William
Winder, GA
2024 Ford Bronco
Thought we should introduce ourselves and our 2022 Bronco WildTrak that is getting some changes.
ADV Fenders +5” ✅
1.5” Mikellis Body Lift ✅
Boss 4X4 swaybar mod✅
Crash bar deletes✅
ARB Toolbox✅
DV8 rear bumper✅
Ford beadlocks✅
Apex valve stems✅
Monster Hooks Rock Rings✅
40X13.5R17 Open Country MT-delivered
Dual shear UCA mounts-ordered
Modify rear bumper with reaper frame mounted tire carrier-not yet
32 Spline 4.7 Spicer FDU-delivered
32 Spline axles-delivered
RK Triangulation kit-ordered
Weld axle tubes to diff housing when installing RK Triangulation kit
RK PB&J lower arms-ordered
RPG UCA-ordered
RPG tie rods-ordered
74Weld S3 steering rack-ordered
74Weld portals with double shear-ordered
NV Motor sports UHMW full skids, diff skid, and diff cover-ordered
Armadillo slantback hardtop-Ordered
Probably missing some random stuff but those are the important(?) bits. Hopefully done by May but we’ll see. The PB&J might be as far as eight weeks out.
How was your experience with the ADV fenders? Looking at getting them for my 2 door big bend, how long did it take to get them and how much was it to install and color match?
SierraBronco
SierraBronco
2022 Bronco
It was about a month
I installed them
Color match sucks despite using Ford’s paint code. But the first time the shop sprayed them they didn’t even use primer. Second time around at least the paint isn’t flaking off after one day but I’m confident their prep led to the mismatch
mikeeshim
Los Angeles, CA
MBZ E350, supposed daily driver
I went crazy on functionality and looks first. I have a 2 door First Edition and I wanted to test and see where the shortcomings were most apparent before doing anything to the suspension. 2.5 years later and what do you know, I much prefer overlanding over rock crawling, and my biggest shortcoming is interior space, so I've devoted a lot of my time to maximize space and installations to the outside. As far as terrain, I haven't gotten stuck yet in rain, snow, mud, smaller rocks, etc, so no complaints in that department for me.
SierraBronco
SierraBronco
2022 Bronco
Make it your own! I’m doing everything I can to utilize interior storage with nothing on the outside while still being able to have a passenger in the back and comfy dogs. 4-door certainly helps with that. It’s almost like each of us is modifying our rigs in the way that best suits our needs and preferred method of recreation. So peculiar that they are different! 🤯🤯😉😉
SierraBronco
SierraBronco
2022 Bronco
Off to the machine shop for some welding
