SierraBronco
SierraBronco
2022 Bronco
Not bad. wouldnt take much to cap it off, if a person wanted to.
Thank you
Not at all. We tapped the inside holes for the lights and it felt like enough thread grabbed to not worry about, but just in case put a nut on the outside as it was easier to access.
SierraBronco
SierraBronco
2022 Bronco
Seats are reupholstered with cooling/ventilation added. Definitely a big improvement. Added suede to mitigate hotspots during the summer. With the fans on the middle setting they put out about as much air as a 2022 Raptor with Recaros on high, and you can feel the air better on your back. Will be a welcome addition for summer wheeling. Factory heat is gone so no heated seats with remote start, but having the heat blown via van might actually be more pleasant compared to sitting on a warm seat. Not certain at this point. Went with blue stitching to match the little blue accents Ford threw in the vehicle for some reason.
SierraBronco
SierraBronco
2022 Bronco
Frame mounted tire carrier installed. Modified the aftermarket bumper extensively to get it to work but got it and didnā€™t even need to weld anything up!
Iā€™ll have to do a review on the Reaper mount. Itā€™s robust up until the tire is mounted. Then you wonder if they kinda just wanted to finish the project and get it on the market causeā€¦damnā€¦itā€™s ridiculously flimsy. Canā€™t say Iā€™d recommend it.
Billy Goat
Pete
Fort Worth
2022 Bronco Velociraptor 400
That's cool you got it to work. My thoughts exactly. Where does it need some beef? I was going to keep the hammerbuilt for GP
SierraBronco
SierraBronco
2022 Bronco
Thanks yo! The extension that holds the tire itself. The rest of the mount is solid but that sliding sleeve thingie is just bent out of somewhat thick sheetmetal. Thereā€™s no way Iā€™m trusting it with a 40 inch tire. Iā€™m going to fab something up out of receiver tubing.
Ninjak
Miami
2021 GT500 2021 Bronco Badlands 68 GTA
Very nice build. That RIG is a crawling monster!
SierraBronco
SierraBronco
2022 Bronco
Thanks! Hopefully it will be when itā€™s done! Just waiting on the portals to show up.
Billy Goat
Pete
Fort Worth
You've pushed me a little closer to picking one of those up.
I would like the ability to operate separately from the tailgate. I'm thinking a hitch pin instead of a bolt at the links and installing something like this with a simple limiter
SierraBronco
SierraBronco
2022 Bronco
I was looking at this but it would just kill the departure angle. I actually removed the hitch for that reason and rely on the rock rings as ā€œframe sliders.ā€
https://www.rigdsupply.com/products/rigd-ultraswing-multi-fit-spare-tire-hitch-carrier
SierraBronco
SierraBronco
2022 Bronco
This was my idea. Extend hitch in red, add latching pin,blue, possibly inside the bumper
Ohhhhh. I gotcha. I had a similar setup on a JK. If I remember correctly it did have a spring loaded pin for the open position as well. I do like the convenience of this setup as far as the tire swinging open with the tailgate using the heim connections. Itā€™s smooth and doesnā€™t hang up at all. In the closed position if I drag the spare it does seem like there should be enough flex as to avoid damage to the tailgate. (Iā€™ll still pop the valve and leave it open in this scenario to allow deformation of the tire, just to be safe)
Billy Goat
Pete
Fort Worth
That's cool. The pics were from The back of my overland trailer
Airing down the spare is a really good idea. So simple. Don't know why I didn't think of it. Forest for the trees
SierraBronco
SierraBronco
2022 Bronco
Airing down the spare is a really good. So simple. Don't know why I didn't think of it. Forest for the trees
I forget where I heard about it. Not an original idea of mine. But leaving the Apex valve open is all me šŸ˜‚
