Somewhere buried in the owners manual is an explanation of a safety feature they refer to as "brakes over throttle". I think it's suppose to cut throttle if you apply brakes to stop you in case of a stuck throttle, maybe this is the problem.Right, but it’s not a matter of waiting for the turbos to spool. Frankly I would think if you’re revving it that high you’ll be in for quite the ride when you release the brake
The problem is that the engine isn’t throttling up at all, or at least not enough to be noticeable. With my Jeeps and their woefully underpowered pentastar engines you could hold the brakes and give it some throttle. You’d feel the suspension change and even when not using the bump up option it could be useful to “push” the body a certain way when articulating.
