Wildtrak and Rock Crawling - which GOAT mode?
Darrow
Darrow
Bronco Wildtrak 2023
So in order to get to some dunes I’m going to traverse some rock crawls. Just curious what other WT owners are doing for slow crawls as far as GOAT modes go. I have been doing it in 4L on normal which has been fine with zero problems. I know I can add rock crawl mode with forscan, but I’m taking a 4000 mile trip and I can’t have anything go wrong with the electronics. The parameters of the rock crawl mode are enticing tho - soft throttle and tight steering. I think normal mode most closely replicates it.
BigMeatsBronco
Allan
2021 FE 2 door
definitely changes the throttle as you mentioned.
JHawk
Ray
Heartland, USA
Fusion Sport
I may be incorrect but..... The goat modes are handy but you have several buttons to push that will come close to the goat mode setting. 4 low, front and rear locker as needed.
I wish that my wildtrak had rock crawl but I think that I can come close to replicating it when needed.
Darrow
Darrow
Darrow
Well the changes in throttle response, steering tightness and shifting points are very noticeable - parameters you can’t change with buttons.
Tex
Cliff
San Angelo
I haven't bothered to try it, but is it possible to select 4L in eco mode? It changes throttle position mapping to be less aggressive sort of like rock mode does, might give that a shot and see if it works.
Also, don't be afraid of forscan, it's hard to mess anything up if you save all of your as built values beforehand. If you've got some time to fool around with it, I'd take that route instead. Rock mode is actually pretty useful beyond just pushing the buttons for you, and there's plenty of other handy features you can add that'll make the rest of your trip better too.
Darrow
Darrow
Darrow
Yea I already got in there and eliminated the double honk and some other chimes. Just something about messing with the UI has me worried. But maybe I will…what were your favorite forscan changes?
jacknifetoaswan
JR
Charleston, SC
2016 Mustang GT/PP
I changed double honk, added Rock Crawl, and changed the EQ settings for the speakers on my Wildtrak. Adding Rock Crawl had zero effect on the UI, other than giving me another option. Of course, I don't have the disconnecting front sway bar, but I don't anticipate any significantly high camber differences in my use cases.
JR
da_jokker
Jeep Wrangler JKUR
Well I ise Mud/ruts for all my actual off roading... manually switching between 4H and 4L as needed.
Sand is for deep sand/snow with alot of slippage and Baja we know so that is really the only "off road" mode we have. Haven't had any issues yet but haven't done any major Rock crawling.
I do have debated enabling rock crawl mode, but for now, I haven't tweaked anything and am stock when it comes to that.
Yamapro
William
21 Bronco
My Bronco is used primarily for off-road and I’ve never used a goat mode. I know what I want the truck to do so I select what I need.
BlueBronco
DFW
To activate the rock crawl goat mode you, literally, just need to change one number of the "code." You are just unlocking what is already there and not reprogramming anything.
helifino16
Ron
Mount Sinai, NY (Long Island)
JR
Same - no issues after adding Rock Crawl. In fact, I've even had it into the dealer for Service on the ECM and they left Rock Crawl activated.
orion
Jeremy
17' F-250, 17' Explorer
Same, for off road, but have used Sport and Eco GOAT modes.
Darrow
Darrow
Darrow
So I got rock crawl added and took it to a local trail. It feels opposite to mud/ruts in steering and acceleration. Got a 2 month trip coming up in a few days, can’t wait to try it out for real!!
Bikeric
Tulsa
1984 4Runner (For Sale)
I like Rock Crawl for the forward camera. Does any other GOAT mode put that on the screen? In all fairness to myself I’ve only ever used Normal, Sport (added via FORScan) and Rock Crawl GOAT modes. That camera is the bee-knees for climbing.
gryphon1231
dj
Miami FL
na
" I can’t have anything go wrong with the electronics" KISS method then!
