Recommendation for a compact torx+ set
GroovyGeek
Boyan
'23 Bronco BD
I already have the Neiko set in the garage but need something more compact to put in my tool roll, along the lines
https://a.co/d/0RuPpCG
Anyone found something they like, preferably solid bits, not security type like above?
Bschurr
NY
CitrusBronco
Everglades
Citrus county, FL
Everglades
B22-2023
Houston
I have a set I never opened. What is Torx plus in these trucks? I’ve been using regular torx bits. Maybe the plus would grab better.
Mjasi3
Chicago
Smocaine
DFW, TX
Cervelo Caledonia
McMaster-Carr sells a good set, that's where I got my Torx Plus bits.
JL8jeff
Ewing, NJ
I think half the stuff is torx plus. It's crazy the mixture of bolts they use and only provide 1 or 2 in the toolkit with the truck. If it's not a snug fit with a torx, it's probably torx plus so don't use the torx on it.
brkdncr
Southern California
Toyota 86
I grabbed a set compatible with the ford toolkit rachet that included a t45 from harbor freight.
GroovyGeek
Boyan
'23 Bronco BD
CalvinT
Calvin
Phoenix, AZ
Umichigan1
2022 2-Door Bronco
Torx and Torx+ are NOT interchangeable. Why they use 2 types of fasteners that are so similar seems pretty boneheaded but Ford was probably forced into it due to different manufacturers and suppliers.
CalvinT
Calvin
Phoenix, AZ
Torx plus of the same size can handle more torque than the standard torx.
Umichigan1
2022 2-Door Bronco
Well, this is good to know. What makes it a PITA is that the fastener design is so similar that most people cannot tell by feel whether they have the correct size of bit. Add to that the lack of general public knowledge of even the existence of torx+ as a standard. If the companies feel the need to use any torx+ fasteners on parts for which the public are likely to require access then make them ALL torx+. That would be difficult however because of the added expense, so, if they must mix the two standards on a vehicle MAKE IT OBVIOUS that two standards are in use and educate the owners and service people.
Sorry for the rant but thank you for the info.
