broncorik
broncorik
They certainly do work with OEM hinges... that is initially what I was running. I discussed my concerns with Tyson about running a spacer, and pointed out that RTR does make a cool threaded bolt that goes into your OEM nut plates and then something can be bolted on top of that bolt because it has a threaded post. If I was going to keep my original hinges, I would definitely get the RTR adapters, and then I would run the hammer built hinge reinforcement plate that's made for the Raptor hinges and use the outer holes. That is just me...
broncorik
broncorik
https://www.rtrvehicles.com/collect...ware-kit-21-bronco-w-o-rtr-spare-tire-carrier
Talk to Tyson at Hammer Built and tell him what you are wanting to do...he has a Raptor in the shop and can tell you what he found out about the flimsy Raptor reinforcement plate and why his setup is probably the best one out there right now. I believe the new Raptor hinge plate is also drilled with the original outer holes for the OEM style hinge but you'd have to confirm that with Tyson.
DoYouBronco
Lux Sponsor (Level 2)
Tyson
El Paso
hpbuilt.shop
working on our own version of the RTR spacers so non raptor hinge guys can still run the HD bracket until they need to carry for weight and install the beefier hinge..
The original design has been Baja proven with dual 2 gallon rotopax, and a 37" tire. The HD bracket was conceived for the regular bronco owners who want to carry even more weight a 5 gallon jerry can and/or a spare tire platform rack with offroad boxes full of gear... It will also fit the Bronco raptor of course...
NORCALGXP
Sacramento, California
2017 Raptor
Trail tested in the Sierra this weekend installed last weekend.
Ford Bronco Raptor Tailgate Hinges installed with Hammerbilt Bracket 20230217_162852
Ford Bronco Raptor Tailgate Hinges installed with Hammerbilt Bracket 1676930223463
Gettyup
Rocky
So Cal
Bullitt Mustang, Expedition
Ok I just received my hinges with the whole assembly glad I just read that I only need the hinges themselves. Now which part number is upper and which is lower?? 🤨
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
Gettyup
Rocky
So Cal
Right now they’re black but will have them painted soon
broncorik
broncorik
Congrats! You will see that when you match the hinge mounting holes that go on the pillar brackets...unbolt the 3 M8s from each one of the new ones, then make sure you trace your old ones before you remove them.
MNBigfoot
MN
I believe the Ford tailgate table, says it's designed to hold something like 80lbs (?), so a sub should be no worries.
broncorik
broncorik
They arrive in black but it is a primer, not a top coat. I had mine sandblasted then powdercoated.
Hemisfear
Bronco Bob
Lotusland
2014 Focus ST
...or 25LBS!
