- Freddie
- Oct 20, 2022
- 20
- 390
- 514
- California
- Bronco
- Wildtrak
So, I dropped off my Wildtrak at Eibach on Tuesday, and picked it up this morning.
In speaking with the Engineering / R&D Manager, they already knew that their Pro Lift Kit for the Sasquatch Bilstein PSD shocks was compatible with the Fox IBP HOSS 3.0 shocks, but they needed a Wildtrak in stock trim, without any additional weight added, to confirm that the springs work with the valving, and confirm that there is no compromise in ride quality since the Fox internal bypass shocks are position sensitive.
When I picked up the Wildtrak, it had 30 additional miles on it, so they were definitely out there testing (I might check my dash cam to see where they went).
I will take some measurements when my tires are cold, but according to Eibach, I have 1.9” of lift in the front, plus 1.3” in the rear, and the truck appears perfectly level (picture of my Wildtrak below taken by Eibach).
On-road, the ride home from Corona back to Los Angeles County was 1.5 hours, and the suspension was definitely stiffer, but I have to give the springs a week or two before offering a real opinion, so I will report back on that. Off-road, I intend to hit a light trail next Sunday, and report back on that as well.
Anyway, here you go:
https://eibach.com/eps-search?year=2023&make=Ford&model=Bronco&submodel=WILDTRACK+4-Door+2.7L+V6+EcoBoost+4WD+|+HOSS+3.0+|+Fox
