2022+ Ford Bronco HOSS 3.0 Eibach Lift Springs
Mitch Panda Motorworks
Mitch
St. Louis, MO
www.pandamotorworks.com
2021 Ford Bronco, 2014 Fiesta ST
Do you love your HOSS 3.0 Shocks, but looking for additional ground clearance? Check out the the Eibach HOSS 3.0 Lift Springs! These springs will provide a lift of 1.9” in the Front and 1.3” in the rear to give your Bronco a nice level stance. This lift may vary depending on added equipment and weight distribution, such as bumpers, winches, etc. This is an excellent, cost effective solution to maintain your HOSS 3.0 suspension while also giving you thee lift you desire! You can rest assured knowing that your product will last as it its backed by a limited lifetime warranty!
Ford Bronco 2022+ Ford Bronco HOSS 3.0 Eibach Lift Springs eibach-e30350560122-bronco-1
We currently have these in stock and ready to ship, Check them out HERE!
derichio02
Bo
Southern California
Bronco Raptor, Bronco Wildtrak, Maverick, Tesla M3
Will these fit 37's? I currently have RPG Collars but would love to swap to springs but I haven't heard of anyone trying these with 37's
Silver-Bolt
Bill
Portland, OR & Eureka, MT
2018 Ford Raptor, 2020 Audi SQ5, 2023 Wildtrak
Springs do not increase ground clearance. Taller tires do.
Mitch
St. Louis, MO
It should work, but we haven't had the opportunity to test that setup in person yet. I'd imagine you'd get just enough clearance to do so without any rubbing.
orion
Jeremy
17' F-250, 17' Explorer
Not necessarily! The only thing that won't be lifted is the rear axle, everything else will.
3People1Body
Christopher
West Virginia
Wildtrak, F150 and Taurus.
I also have the 2.25 RPG collars. I want more than 1.3" in the rear, due to my (heavy) RTR leveling kit (RTR bumper and RTR Spare Tire holder). Also, when I get around to adding a front winch, it's going to drop the front even more.
Any future option of a higher spring rate? These aren't going to help much (for me), but I would like to get rid of the perch collars, they ruined my cushy HOSS 3 ride. 😉
Mitch
St. Louis, MO
I am not 100% sure if a higher spring rate option will be available, but I could definitely see it! Especially considering they have the option for their coilovers.
TEAMSLO
NV
youtube.com
23' Bronco 2.7 4d Oxford White & 22' JLURD
I would also be interested in a high spring rate for the rear as the 1.3 will just make me squat with the added weight I have.
orion
Jeremy
The lowest point is still the lowest point.
How often are you hitting your rear axle? Tire placement usually minimizes axle hits! Just saying, suspension lift will lift most of what is getting hung up on trails!
JP05
jonathan
Indiana
bronco
I went with the eibach spring kit for my hoss 3.0. Installed about a week ago. With my 37s. I had some slight rubbing on the inner fender liner. I bought the max tire kit and only used the inner fender bracket so far. And no rubbing driving around town. But I think it will probably rub off road.
wheel offset is going to play a role in clearing. I went with 0 offset.
Might have been play with -12
Ford Bronco 2022+ Ford Bronco HOSS 3.0 Eibach Lift Springs 1000021798
Wildruby
Canada
How’s the ride?
JP05
jonathan
Indiana
bronco
It rides a little stiffer but I am happy with it as far as on road. Have not had an opportunity to take it offroad yet. Been nothing but rain since I installed.
But on the road it feels good to me. Less body roll in the turns.
derichio02
Bo
Southern California
Just checking in. Looks like you also still have a bit of rake is that accurate? Also have you went off-road? Any additional modifications needed?
JP05
jonathan
Indiana
bronco
hello, yes i did still have some rake to it. after it settled for a couple days i only ended up with about 1/2in rake. since the lift springs i added part of a leveling kit. to the front and the rear. just on top of the struts. i bought 2 kits and used half of each kit. i also ended up doing the jks max tire kit.
I have it in the shop getting aligned today. and going to take it to the badlands this weekend and do a test run.
