4" lift for 2023 Hoss 3.0 suspension?
ronnyek
San Luis Obispo Area, CA
2023 Bronco Wildtrak, 2018 Mustang PP2
So I finally just got my wildtrak after at least 2 years. The stock ride height isnt terrible, and thinking a leveling kit might be fine... but I've also seen 4" lift kits on broncos, and I feel like that's what the bronco should have looked like stock.
I'm just curious if there are any options for a ~4inch lift that's not gonna make the ride worse or anything. Stock ride height makes tube steps... kind of akward =)
(I am over the moon that I finally got it, and all the worries I had about options I chose or didnt choose or colors, has gone right out the window)
JackTripper
The Beach
Enough
Nice, congratulations. Iā€™m still waiting on a 1 inch lift spacer to be worked out by some manufacture.
Ford Bronco 4" lift for 2023 Hoss 3.0 suspension? 77BCA0A2-4310-437C-BD64-180BB85194C9
Silver-Bolt
Bill
Portland, OR & Eureka, MT
Lifting it 4" is going to require removing the HOSS 3.0 or added some janky spacers. Both of which will affect the ride quality. You are not going to get a 4" lift with the same ride quality as the stock HOSS 3.0.
KompressorV12
Portland, Oregon
19' Jeep Grand Cherokee High Altitude
First off there is no 4" lift for HOSS 2.0/3.0. HOSS 3.0 sits slightly lower than HOSS 2.0, estimated around .3" lower so you may get 3.3" over HOSS 3.0 with the available 3" suspension lifts available. If you go the 3" spacer route you're taking your springs and preloading them 3". You can probably visualize how this impacts ride quality. Your only option is to swap the entire suspension, UCA, springs, shocks, lower link to get to your 3" with equal if not better ride quality. That's what I'm doing.
ronnyek
ronnyek
I actually found this link to a post here on this forum where a guy bought a rough country 2.5 inch lift and installed on a 2023 wildtrak with hoss 3.0. Its a 2door but says rough country said it should be fine etc.
https://www.bronco6g.com/forum/threads/wildtrak-hoss-3-0-build-almost-done-hahahahahaha.63537
I'd totally be down for even 2.5" and that kit seems like it wouldnt compromise stock hoss 3.0 stuff (at least not like a spring perch collar might).
I hope there are options to do something like that RC setup because I think the end result was a good looking bronco, that theoretically rode like stock, just had a bit more clearance
broncodream
Austin, TX
2023 2-door Wildtrak Eruption Green
I ordered mine with the same exact spec looks like. Supposed build date of 4/12. Good luck and enjoy!
MNBigfoot
MN
.......... HOSS 3.0 sits slightly lower than HOSS 2.0, estimated around .3" lower ................
According to Ford Specs they are the same. Was this from an article or one guy with a tape measure?
Valhalla
Valhalla
Cleveland Tn
2023 Bronco,1996 Bronco, F350, JKU, MKZ, Silverado
3" BroncBusters Body lift on mine allowed me to go 37's You can look at my build for the particulars.
NJNMDoc
Southwest
Bronco Wildtrak
I just posted a field report on the RPG perch collars. I did not find them to compromise ride quality in any meaningful way. Good luck you!
kbernard
OBX,NC
23 Tacoma work truck
Foutz, RPG, and SVC make perch spacers of various heights. If you do go all new stuff I did Eibach on my dads and I can tell you it was better than HOSS 2.0 as ride quality.
NOBUKSGIVN
four corners
2023 Bronco
I used the zone 2.25 lift specifically for the Hoss 3.0. I also used my already installed zone leveling kit based upon the addy of a 12k winch and the Barnes all steel full skid plates.
Iā€™m going get the new Fox 2.5 which will eliminate the spacers and be more durable. I will still use the leveling kit though. Running 37x12.50 with the aforementioned lift, jks clearance kit, DV8 front inner fenders to ensure no rubbing I have a bit in the rear when Iā€™m in extreme flex but I believe adding the matching inner fenders will eliminate that as well
Ford Bronco 4" lift for 2023 Hoss 3.0 suspension? 71F7FF04-7C73-460A-9DFB-E3164DCA5949
Midnight_Blue
Jeremiah
Los Angeles
I wonder how often anyone orders prime rib and then says, hold the meat bring me spam instead, Iā€™ll pay extra for that.
