Midbass from kickpanel speakers
mjp2
2021 Cyber Yellorange Bronco Badlands
Those are some really nice adapter plates!
Roland
Ohio
2022 Bronco
Thanks. I had a buddy print them for me. They worked out well.
Dan-O
Dan
Fountain Hills, AZ
I installed Kicker component 6.5s in kick panels and was very disappointed in bass. I pulled speaker and lined entire kick panel enclosure with killmat and also used killmat to create seal around speaker mount. Sounded great but could hear some pfffftt escaping around the trim clip holes of door jamb area. Added some more killmat around those holes and I was very pleased with bass. It takes some detailed time getting the killmat into all the nooks and crannies in enclosure but after all said and done the bass sounds great. Of course a seperate sub would of course sound better, but i decided against a dedicated sub.
heathw101
keith
Baton Rouge, La
2024 Brinco
Pics of the Sounds Good Stereo adapters I used. Really good quality
Ford Bronco Midbass from kickpanel speakers IMG_0402
Ford Bronco Midbass from kickpanel speakers IMG_0403
LAX-DAD
G.L.
Dualing Broncos
Late to the conversation but wanted to share my experience for what it's worth. Main issue has to do with airspace in the kick panel of the bronco as to why hard to get decent midbass. Car speakers are predominantly designed to work in larger door cavity. FYI, attached photo of passenger side where you can see the openings but can still be sealed up somewhat.
In my quest I started to look at speaker TS parameters, in particular lowest Fs and QTS. I am no expert so those in the chime in on the technical, but in small air space a low QTS and Fs driver is an indicator of a speaker that will play lower frequency in small air space.
I guessed on the airspace in the kickpanel at approximately .2 cubic feet then started looking at drivers and found the following at Madisound and with their help identified the following:
SB Acoustics SB17MFC-4 will play down to 85Hz in .2 cubic feet
Morel CAW634 3db down at 80Hz
Satori MW16P-4 or MW16TX-4
Scan-speak 18W/4531G00 3db down at 80Hz
Scan-speak 18WU/4741T00 3db down at 85Hz
Sealed up what I could, purchased the SB17MFC-4 for testing. Made some adapters tuned with dsp, band passed frequency to 80-400Hz and what do you know, magic.... midbass out of the bronco. Happy with the results and knowing I was heading in the right direction, moving on to upping the wattage (300 watts a side) to the kick panels so I stepped up to the Ciare HWG160-4 speakers. I am after SQ so I like headroom. If anyone is interested, I have the SB Acoustics SB17MFC speakers with custom adapters listed on ebay.
Happy to share more detail. In the Houston area show you or should I say play for you what I've put together if that would help.
Ford Bronco Midbass from kickpanel speakers IMG_7674
AZCoyote
Wiley
Phoenix
2024 Big Bend Sasquatch
I don’t have a write up. However here’s some pictures of what I did.
what was the black rectangle of plastic used for?
Did you actually mount the amp underneath of the center console?
Do you have a link to the 3-D print file by chance?
404
Roland
Ohio
2022 Bronco
The black plastic was used in place of the foam pieces that the factory puts in behind the big electrical connector. I glued them in trying to make it airtight. I also used spray foam to seal the area where the body clips pop in and where the foam is that allows wiring to pass thru up high under there.
The amp is located just in front of the center console more like where the cupholders are.
Unfortunately I do not have the link for the 3d model.
AZCoyote
Wiley
Phoenix
Are we talking Home Depot wall sealer foam or somethingSpecial?
thanks!
404
Roland
Ohio
2022 Bronco
I used the home Depot special. Just use it sparingly!
23OBX2.7
AB Canada
2023 Bronco
I read a lot on polyfil and I'm not convinced it works. I also tried filling the sub enclosure in my FoST and heard no difference, so I didn't bother with the Bronco and I have no complaints with it!
The rag in the4 port will do virtually nothing...
How did all that sound deadening work? Plug the port?
Hemisfear
Bronco Bob
Lotusland
2014 Focus ST
Great I guess!
The sound is awesome and I have no buzz and the sub really hits nice...
Yes, I epoxied in a piece of plastic similar to the enclosure material...no foam fill! lol
23OBX2.7
AB Canada
2023 Bronco
Great I guess!
I just did 16-17 sq ft sound deading inside out of the enclosure doubling it up on the exterior plus did the sheet metal and final 3-4 sq.ft on floor. Left port open. No rattles sound decent for cheap MB Quart sub.
heathw101
keith
Baton Rouge, La
2024 Brinco
I have been thinking of doing the same with raw drivers and a low QTS because of the small enclosures in the kick panels. I know most of these drivers are 3+ inches in depth. Where you able to easily fit them and use the factory grills?
akturbo
Seattle Eastside
Is anyone capturing before and after frequency response measurements when making changes to the kick enclosure? I've attempted to seal up the area, still have full drop off at 100hz. Near field frequency is good, can't tell if I'm fighting the enclosure or cabin acoustics (+soft top). AudioFrog GB60s with 200W RMS to each.
akturbo
Seattle Eastside
I went through this effort I cut plastic pieces to close the large hole and glued it in place. Then I 3D printed some adapter rings for dayton audio 6.5’s. Ran them to a kicker key mounted above the glove box. I used spray foam to seal up inside where the clips protrude into the cavity. I ran the speaker wire in from above where there is a foam seal and sprayed some expanding foam to seal that as well.
I measured this setup with REW and it gets down to about 55hz fairly decently. I ran that for over a year before I threw in a sub.
How thick of plastic did you use? I thought about using spray foam as well, may have to go your route since it worked for you. 55hz would be great compared to my 100hz!
