Lower ball joint nuts missing or fell off??
Chrome_Pony
Chrome
The Great Land
SierraBronco
Absolutely. Replace the bolts. Not saying it is good practice to reuse them. I was just being lazy. Just saying Bolts don’t get all the blame.
As much as you have retorqued suspension bolts they should be toast by now. 🤣
Solution-ball joints can’t loosen if you don’t have ball joints.
Ford Bronco Lower ball joint nuts missing or fell off?? IMG_1275
dgorsett
colorado
F250, Mustang, Explorer
I blamed the 2nd use of a lock nut on my deal and then looked at some pics taken during my coilovers install and the nut in question had clearly not been torqued. I have to assume I left it hand tight. All those lock nuts seem to work really well multiple times, even to the point of possible galding of the bolt threads (a forum member confided in me that he had this happen).
When I see posts of parts exiting the convo I usually assume improper aftermarket work, you may be the only one big enough to admit it. On my 5100 install I didn't tighten the top three coil over nuts on the left front. Racket on the way to the Mexican restaurant informed me, luckily I wasn't half way up Imogene at the time.
Ford Bronco Lower ball joint nuts missing or fell off?? 20240801_130558
gbub
Gary
Costa Mesa CA
2002 Ford Ranger FX4, 1969 Fairlane Cobra, 1970 2800CS BMW, 1961 Austin Healey S
I gotta say, I'm not so sure this is 'as built by Ford,' since with 13k miles on it it's already got a new set of tires - those aren't factory tires on any model I'm aware of. If it's been lifted or any of the suspension has been worked on, without a cross-hole for a cotter key there's a good bet those were 'torque to yield' nuts, meaning they should have been replaced when it was taken apart.
I have a sneaking suspicion that what you encountered with that rig (presuming it's not yours) is someone who isn't telling the entire truth.
Are torque to yields nut a real thing? I have used torque to yield bolts but I don't see the purpose or what would yield in a nut.
Steve_In_29
St Johns, Arizona
2024 Heritage Limited, 2 Door, 1973 Bronco, 1999 Ranger, 2007 F350
Back in the day all ball joints had castle nuts with a cotter pin. Jeeps still do.
Which can also be a bad thing when the right retard works on the vehicle.
A woman brought her vehicle into a friend of mine's shop after her friend had worked on it.
That "friend" had simply used the cotter pin (NO NUT) to hold one of the steering ball joints in place.
Ducati1098
No, they’re not. I think he meant one time use, not torque to yield.
BroncoChallenger
2024 Bronco
While it's not a true 'torque to yield,' one-time-use is basically the same thing. And I'm not a fan...though it turns out our Challenger also has them (on tie rod ends, just replaced them this weekend).
I miss the old days when there were physical preventatives in place.
gbub
Gary
Costa Mesa CA
I agree but sometimes castle nuts and cotter pins can be a hassle too.
SierraBronco
So far we’ve seen Ford balljoints outlast the LCA and tierod connection points on 74weld portals, and now the LCA connection on Belltech knuckles. (With Tibus portals)
Starting to feel pretty damn confident on how strong those factory ball joints and nuts are…
Ford Bronco Lower ball joint nuts missing or fell off?? IMG_1478
Ford Bronco Lower ball joint nuts missing or fell off?? IMG_1480
telenerd
Laramie
Subaru
Well I’m not done, but I torqued all my bolts on driver side. The only loose nut was the lower ball joint!!
Swaybar, upper ball joint, tie rod, top hat bolts upper and lower shock bolts all tight to ford spec. Skids all tight and upper control arm bolts to spec. Only the dam lower ball joint was loose. I bet it had 75 pounds of torque or maybe less. From what I read it’s suppose to have 85ft pounds. I paint marked all the bolts. Gonna do passenger side in the morning.
telenerd
Laramie
Subaru
Passenger side lower ball joint was loose too after checking everything! I guess check your bolts. It wasn’t as loose as the driver side for me.
Fordified1
Bob
Mid South Texas
When my son did the alignment on ours at less than 5,000 miles, he said one side lower control arm bolts were barely tight enough to hold alignment.
