Flat tow failure
Peter Cole
Peter
Oregon
23 ford bronco
I thought I’d share my experience with flat towing my new Bronco. About 4 months ago we did a National parks trip. We were flat towing the bronco behind my F350 with a truck camper on it.
Half way through our trip in South Dakota I went to unhitch the bronco and started it. Immediately the fan kicked on, the dash lit up, the trans temp was at 330 degrees. The transmission was fried. And at this point not sure what else was damaged.
Up until this point I had put the vehicle into flat tow mode several times and had towed it a couple thousand miles from home with no issues. I had no idea what went wrong.
So we decided to transport it home back to Oregon and continue on our trip.
It’s currently at its third dealership and hopefully will be repaired soon. It’s needs a new transmission, transfer case, and oil cooler. $9800 with labor. I’ve been fighting with ford because I feel I did everything correctly but they are denying my warranty claim. Apparently if your transmission fails while flat towing it’s not covered. I’m pretty disappointed with Ford right now. A big reason for choosing the bronco was the ability to flat tow. But I’m scared to ever do it again.
I know I’m not the only one here that’s had this issue.
WheresMyBronco
Los Angeles
2023 Badlands
Lots of people on here had the same experience... maybe take all of those in with you to help you fight your case
BlueWaffle
Maine, USA
2023 bronco, and a trio of 80s GM's.
People here AND on the 5g ranger forum...
Really shitty setup by ford.
dgorsett
colorado
F250, Mustang, Explorer
Man, about the time I think MIC tops quit delamming, or 2.7's quit blowing up, or flat tow trannies stop toasting here comes another. :( Sorry man
Rydfree
Benny
Alabama
G6Bronco
Tom
G6 bronco
same thing happened to me, i posted back in August 2023. Ford was HAPPY to have me EAT $6,800.00 of their BAD engineering. We are in the process of filing suit under Magnuson/moss [lemon law]. I have been a ford owner for 40+ years and could not be more frustrated, disappointed disgusted with ford and its "customer care" philosophy. I do wish you well but I have no hope in you getting satisfaction from ford. The worst part is they, Ford, couldn't care LE$$.
SuperDave150
Lubbock, TX
Ford F-150, Ford Edge
@Ford Motor Company
i got the “System off to save battery“ message today on my 2023 OBX with Advanced 4WD. (It had been parked for about 5 days)
I noticed that the transfer case mode had switched itself from 4A (which I always leave it in during snowy weather) into 2H.
While this isn’t a big deal as a daily driver, it would be catastrophic if I were flat towing - for the transfer case to shift itself back to 2H in the event of low voltage, etc.!!! That would certainly explain some “mysterious“ contested transfer case and/or transmission failures when flat towing (recreational towing).
gweberg29
Gary
Colorado Springs, Colorado
2023 Badlands Sasquatch
HOPE SOMEONE FINDS THIS HELPFUL - I WILL POST ON ALL THREADS BELOW - WORK IN PROGRESS
Flat Tow Transmission Failures – as of 02/22/23 – A work in progress – May have missed someone
Thread 1 – (06/03/22) Bronco won’t go back to drive after disengaging tow [2] – Checked 01/18/23
Thread 2 – (10/28/22) Neutral Tow / Transmission Problem [12] – Need to go back through – Long tread
Thread 3 – (07/09/23) Ford claims flat towing our 4 mo. old Bronco destroyed the transmission (not covering under warranty [14] – Need to go back through – Long tread
Thread 4 – (08/08/23) Flat tow won’t disengage [1] – Checked 01/18/23
Thread 5 – (08/16/23) Flat tow failure [3] – Checked 01/18/23
Thread 6 - (11/18/23) Flat tow failure (2) [1] – Checked 01/18/2
Thread 7 – (08/28/23) Bronco Raptor Transmission Troubles Anyone? [3] – Checked 01/18/23
1) @Rgarrison58 – Thread 1 – 6/3/22 – Transmission Failure – Ford WILL cover
2) @Bad Sas – Thread 2 – 10/28/22 – Transmission issue – No resolution posted
3) @Blue Bulldog – Thread 2 – 4/12/23 – Transmission failed – Ford will NOT cover - Suing
4) @GddyupGG – Thread 1/2 – 4/19/23 – Transmission failed – Ford will NOT cover – Insurance WILL cover
5) @G6Bronco – Thread 4/5/3 – (08/16/23) – Transmission failed – Ford will NOT cover – Hired attorneys
6) @Bukin67 – Thread 7 – (08/28/23 – Transmission failed – Ford will NOT cover
7) @aknavy – Thread 2 – (08/21/23) – Transmission failed – Ford DID cover
8) @Lisa Aiudi – Thread 3 – (09/09/23 – Transmission failure – Ford will NOT cover
9) @delynn.gibson – Thread 4 – (09/21/23) – Stuck in tow mode – Trase electric motor failed – Ford will cover
10) @Peter Cole – Thread 6 – (11/18/23) – Transmission, Tcase, Oil cooler failed, Ford will NOT cover
G6Bronco
Tom
G6 bronco
happened to a bunch of us. Same story, ruined transmission, vacation, built ford tough means tough to warrant. VERY UNHAPPY WITH FORD. they need a class action filed. perhaps when it get to the hundreds of cases something positive will happen.
Fordified1
Bob
Mid South Texas
Will people never learn?
Learn what? That Ford refuses to admit that have a problem and fix it and warranty the failed transmissions?
Fordified1
Bob
Mid South Texas
All the flat-tow related trans failures that I’m aware of were equipped with the Advanced 4WD system. (4A on the selector). Use that information in court.
Fordified1
Bob
Mid South Texas
When flat towing my old '65 Mustang with C4 auto trans, to avoid possible issues when going longer distance, I usually unbolted the rear driveshaft where it mated to the diff and tied it up. Given all the Bronco flat tow issues, I'd probably do something like that to be on the safe side.
On a related note, I wonder how well these driveshaft disconnect kits work? Apparently some people use them to flat tow otherwise untowable vehicles. Not sure I'd want to count on the assembly holding up off-road though.
Since I don’t have the Advanced 4wd system, I’m more confident that I’ll be fine flat towing. I used to disconnect the driveshaft on my excursion to flat tow, but that gets extremely old.
The driveshaft disconnects do work, though I wouldn’t want that on a Bronco that sees anything more than pavement. And they are not cheap if you price the parts AND labor. And then you still have to trust that the front axle disconnects are functioning properly.
I’d love a manual shift transfer case and front hubs option for what I do.
I WANT @Ford TO ADMIT THEY HAVE AN ISSUE AND FIX IT! And WARRANTY ALL THOSE FLAT TOW RELATED FAILURES THEY DENIED!
