Extending tailgate spare tire rubber bumper?
Roost
Cave Creek, AZ
2023 Bronco Wildtrak
I went with 17x9 with a -12 offset and now have a gap/lost lower support from the rubber bump stop to the tire. Anyone have any suggestions where to find an extended bump stop replacement? I am only finding replacement parts for Jeeps. I attached a photo showing the issue I’m having. Thanks!
Ford Bronco Extending tailgate spare tire rubber bumper? IMG_3479
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
If this is supposed to rest on the spare tire, mine never did from day one. I have a bit of a gap like you do.
Following to see what the recommendations are.
Ninjak
Miami
Will look to see what people say as well. Though honestly, my tire is very secured, does not move, and I am not sure what the rubber touching my tire would do.
lapazleo
2022 bronco badlands
3 different lengths available from Ford. A piece of aluminum tubing inside the existing bumper with a rubber tip from a cane or walker. Plenty of threads on here covering this.
lapazleo
Spreads the load to prevent stress cracks. That spare vibrates a lot more than you think going down the road there by stress cracking the sheet metal. There are posts on here from those who found out he hard way.
Tricky Mike
21 Bronco
There are some universal cut-to-fit bumpers for jeeps that will work. I used some from Energy Supension.
FreddieLee
Freddie
Bronco & Tesla M3
I installed a set of Barnes Extended Bumpers when I switched to 37's and 0 offset wheels.
DW HOG
Dennis
Ohio
Jeep Compass
Measured what I needed which was 3/4” and went on e-bay and found a rubber 2” x 3/4” . Added it to the Ford rubber
Ford Bronco Extending tailgate spare tire rubber bumper? IMG_1896
Roost
Roost
Cave Creek, AZ
Custom! Nice!
604Bronco
British Columbia
www.bronco6g.com
Anyone else with the factory sized wheel/tire combo (35” Sasquatch setup) find their bump stops aren’t touching the spare tire? I assumed this was just an aftermarket setup issue.
Doubleajaybrock
Aaron
2023 Bronco 2 Door 2.7L
I sent you a PM
Bad_Bronco
Peter
Port Coquitlam, BC
1963 Chevy Nova SS, 2021 Ford Bronco WildTrak
I used this.... https://barnes4wd.com/products/bronco-spare-tire-extended-bumper It is very good, as you can trim it to make fit. Soft rubber, easy to cut, and stays in place. I get no movement from the tire. It only acts as a steadier for the tire, but works well.
