Status
Not open for further replies.
PCDan
Dan
Park City
1968 Ford Bronco
I think I'll go ahead and get the tubular Icons. The billet is overkill for my needs.
Thanks for all the work figuring the tie rod out, really appreciate it.
I have two spare Ranger inners and the JKS sleeves. Not going to spend a ton on band-aids. And in the mean time while we all wait for a proper fix I’ll just try to be smart when wheeling.
And believe it or not … it’s often driver fault when things break 😉
Tricky Dick
Dick
PNW
www.TD-Distributing.com
Thanks for all the work figuring the tie rod out.
I have two spare Ranger inners and the JKS sleeve. Not going to spend a ton on band-aids, and in the mean time while we all wait for a proper fix I’ll just try to be smart when wheeling.
Believe it or not … it’s often the driver when things break 😉
I agree driver plays a big part. I still haven't seen confirmation that any stock Bronco has broken one either.
Frankly at $10-20 a pop I'd rather have a Ranger tie rod be a fuse than possibly wipe out the rack.
DREWR13
DREW
ATLANTA GA
2003 Miata....
This is my thought as well. I would much rather throw a new inner on than deal with a blown rack on a trail somewhere.
VoltageDrop
Fidalgo Island, WA
23, 69 Bronco
Tank trap guy was all stock
sea382
Riverside, CA
I ended up ordering these:
https://www.levelupsuspension.com/products/level-up-suspension-tie-rod-sleeves-21-bronco
I was worried that the JKS threads were not coated (or any powdercoat/paint that was one them would come off when they were installed) and would rust and seize over time. The rough country ones looked good too, but they covered most of the adjuster (especially when you loosen it) which seems like it would make alignments difficult.
Ford Bronco Exploring off-the-shelf tie rod upgrades 1653273181438
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
Google seizing and stainless as your statement is a contradiction.
sea382
Riverside, CA
I had stainless tie rod sleeves on my Colorado for years with anti seize and never had any issues. This kit comes with antiseize as well. I really think the JKS raw threads will be even worse over time...
The difference here between a stainless steel fastener and a stainless steel tie rod sleeve to me is how much its being tightened. A faster is usually torqued to a specified amount, which can cause galling of the threads. Here the sleeve is being used as a nut. If you ask any good alignment tech they will tell you not to overtighten the tie rod nut. There is no need, especially since even if the nut come loose the tie rod end cannot rotate. The inner tie rod would have to rotate in it's ball joint to have the tie rod actually come loose and fail.
VoltageDrop
Fidalgo Island, WA
23, 69 Bronco
Tricky Dick
Dick
PNW
Today we proved the Ranger tie rod will get you home. @Tarheel_Wes broke one on Dickey Bell at Uwharrie. A trip to the nearest auto parts store netted a Ranger tie rod and we got him fixed up. He reported it drove well.
If someone in the group had carried one, we would have only lost half an hour and gotten another trail or two in. It's cheap insurance, grab a spare guys.
Tarheel_Wes
Wesley
FJ
Amen. And thanks again. You saved me.
Tricky Dick
Dick
PNW
I'm glad we made it work. Your tow home could have been pricy.
The Broncbuster splint to get it off the trail was pretty slick too. I love that this community is coming up with homegrown solutions.
Tarheel_Wes
Wesley
FJ
Yes without that it woulda been a trail change in a really tricky spot
Tricky Dick
Dick
PNW
Hey, tricky is my specialty. It was easy peasy in the parking lot though.
bodean
Shawn
Alberta, Canada
76 Mini, 99 4Runner, 07 FJ Cruiser, 16 Tacoma
Do tell?
Where’s the best place to get cheap ranger tie rods.
Status
