- Feb 26, 2021
- 70
- 229
- 371
- Silverdale, WA
- Lots of Jeeps and one lone Bronco (so far)
- Base
Seems like a nice solution but how does an alignment tech adjust the inner tie rod since this covers up the flats on it?
I don't follow. You can't turn the outer unless you break it free from the knuckle and then you can only adjust in 360 degree increments?The alignment is not on the inner. The outer is either turned in or out on the inner to get the desired toe adjustment.
So the sleeve would need turned in, then the jam nut for the outer needs turned in and then the adjustment made to the outer, in or out, then jam nut back tight, then sleeve back tight.
The thing to remember is that after they have been together for awhile and encounter the elements they will tend to rust together and will usually require cutting them off and replacing with new to get the alignment in spec. This is very common in the "rust" belt.
Yeah I misread it, was thinking of it all wrong. (wife was distracting me while I was trying to respond). You would have to use a pipe wrench or something similar just above the sleeve to adjust.I don't follow. You can't turn the outer unless you break it free from the knuckle and then you can only adjust in 360 degree increments?
This is where you're losing me. The normal alignment procedure is to loosen the jam nut then turn the inner tie rod because you have infinite adjustability on it. I'm sure I could make it happen if I was aligning it myself but I'm just wondering if I'm going to get a "nope!" from an alignment shop once they take a look at it.Yes, to adjust the toe, you have break it free from the knuckle and then spin the outer tie rod to the proper spec.
It is exactly the same as adjusting with the stock jam nut. Just think of that sleeve as a longer nut.
Sorry, my typing didn't match what was going on in my head...This is where you're losing me. The normal alignment procedure is to loosen the jam nut then turn the inner tie rod because you have infinite adjustability on it. I'm sure I could make it happen if I was aligning it myself but I'm just wondering if I'm going to get a "nope!" from an alignment shop once they take a look at it.
I installed the jks sleeves about a month ago. There wasn't a mention of using anti seize. Now I'm concerned about corrosion. I don't want to go through the hassle of taking the sleeves off. Would sprayimg some fluid film inside the top of the sleeves prevent corrosion? Are the sleeve threads destined to rust to the tie rod threads? Any other suggestions?Yes, to adjust the toe, you have break it free from the knuckle and then spin the outer tie rod to the proper spec.
As @Snacktime posted above, there is just enough room to get a thin wrench or pliers on the flats of the inner tie rod to hold it while breaking loose the sleeve (locking nut). I should've mentioned that in the video.
To keep corrosion down, we highly recommend using antisieze all along the inner tie rod, except for where the sleeve is threaded on the inner tie rod, useable Loctite there.
My thoughts exactly, I like these shorter ones that don't cover the adjustment spot.Seems like a nice solution but how does an alignment tech adjust the inner tie rod since this covers up the flats on it?
How do you know they come with a little packet of anti-seize?My thoughts exactly, I like these shorter ones that don't cover the adjustment spot.
https://www.levelupsuspension.com/products/level-up-suspension-tie-rod-sleeves-21-bronco
They also came with a little packet of anti-seize
