Status
Not open for further replies.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
Well as soon as this is sorted out , I'll buy a set of Tricky Dicks HD T-Rods....I'm not opposed to opening up the taper ESPECIALLY if it means we are getting a bigger ball joint too? Maybe try sourcing some reamers or taper cutters in bulk-buy to include with the Tricky Rods? Just an idea.
I really doubt I'm going to try to sell anything prepackaged. I'll just be happy if the community can benefit. It's easy enough for anyone to source the parts from your favorite store with the part numbers or just the original model it was for.
BigMeatsBronco
Allan
2021 FE 2 door
Well took er for a late night spin...Absolutely Fantastic!!
I gained nearly 1.25" compression travel in the front!!! Unbelievable that I have a FULL 12.5" front wheel travel now!!! The recipe is OEM UCAs folks. And shaved bumps with RC knuckle uprights.... obviously my Fabtec UCAs were bottoming out in the uniball angle available before this.
My real desire here was to straighten out the tie rods angle and this setup fixed that and also gets nearly FULL use of the 80 degrees available from the upper ball joint.... here's a few pics....I'm so happy I'll probably start another thread about this.
Ford Bronco Exploring off-the-shelf tie rod upgrades 20220429_220458
Ford Bronco Exploring off-the-shelf tie rod upgrades 20220429_215750
Ford Bronco Exploring off-the-shelf tie rod upgrades 20220429_215419
Ford Bronco Exploring off-the-shelf tie rod upgrades 20220429_215410
BigMeatsBronco
Allan
2021 FE 2 door
Yeah I'm with ya there...it looks like between the Tie rods you found and these knuckles from RC, I think the rack and tie rod issues could be completely eliminated. And gain a bit of wheel travel too!
And all these parts together are less than the $430 BB band-aid everyone is swooping up...kinda funny 😁
Tricky Dick
Dick
PNW
That's impressive.
BigMeatsBronco
Allan
2021 FE 2 door
Here is a before and after pictures of the tie rod angle at full droop...what a difference! Imagine for yourself where the force is directed when the tire impacts a rock or stump on the outside edge....the force is transfered across the tie rod into the rack ...and when the tie rod is a t a 45 degree angle then HALF of the force is pushing UP on the inside of the rack, not across. This is where the rack fails...simply when the force is in the wrong direction.
Ford Bronco Exploring off-the-shelf tie rod upgrades 20220430_080348
Ford Bronco Exploring off-the-shelf tie rod upgrades 20220430_080400
BroncoAZ
Mitch
The CV angle looks a lot less severe in the second pic?
Tricky Dick
Dick
PNW
Check and see. My bronco has not shown up yet so I cannot check. All of the videos I have seen show that a 21mm socket is needed for the outer tie rod end. A standard M14 nut uses a 21mm socket. If it was M12 it would use a 19mm socket. This obviously is less accurate than just measuring, but that not an option for me at the moment.
OK I just physically checked it. The stock Bronco outer is undoubtedly 12mm.
Nobody
Stanwood, WA
www.snowtrek.org
1970 Bronco
This is good stuff. Seems like there is some potential of bump/flex steer if the LCA and tie rod are not traveling along the same arc.
Tricky Dick
Dick
PNW
That was my concern but maybe it's not enough to worry about. If @BigMeatsBronco could do some high speed testing, seeking out bumps, it should become apparent shortly.
Nobody
Stanwood, WA
www.snowtrek.org
1970 Bronco
Yes, high speed would be the main concern, as the suspension is being worked, is the tire up there shaking, and potentially leading to some fatigue failure or prematurely wearing out the TRE.
I suppose you could pull the coil over one side and then cycle the suspension and see if anything is going on.
Tricky Dick
Dick
PNW
It'd be helpful to have it on an alignment rack to do that so you could accurately measure before and after. There may be some toe gain through the cycle from the factory even. I think toe loss would be most important to avoid, it could cause darty-ness.
DREWR13
DREW
ATLANTA GA
2003 Miata....
Excellent thread here. Going to order some of the ranger inners for some cheap insurance on the trails.
BigMeatsBronco
Allan
2021 FE 2 door
Yeah that's next on my list...right now it is just an eyeball alignment and I know my castor and camber are way out of spec too so there lots to do still just to see if it will even work correctly. ...drives fine right now but I can tell it's not quite right yet. I'll get an alignment done Monday or Tuesday.
jdamach1
Danny
1955 Fairlane, 1970 Mustang Mach 1, 2023 Bronco
Tricky Dick and the rest, thanks for all of this great information. Were you able to determine if the '04-'08 F-150 Inner will work with the '15 Camaro Outer? I'm about to order my spares from Rock Auto for my Colorado trip and need to determine if I need to order the Ranger or F-150 Inners. Thanks for the help.
Status
