Change Driveline Fluids Early!
Aonarch
Jack Hoff
MT
No EPA fed here bud! ;)
thanks a ton. Would never have thought of alcohol. I have some denatured from recent shower reseal with silicone.
Will take a week between when I change the front diff fluid and doing the T-case.
Perfect and to clarify.
Step 1: rinse out with hot water. Hot water will help break down oils and dislodge gunk.
Step 2: either straight alcohol, or mix alcohol with hot water. Play around with the ratio.
Step 3: hot water rinse
Step 4: dry dry dry, use forced air and shop towels if you can
malpais
Some old Honda
This may be a dumb Q, but is the automatic transmission sealed in the Bronco? I noticed I don’t have a transmission dipstick like some older cars.
If not, should the auto trans fluid be changed early as well?
Aonarch
Jack Hoff
MT
There is a dipstick, it is just only accessible right by the transmission. I forgot what side it is on.
Check owners manual for the "official OCI," but personally I like doing drain and fills every 40k.
CarbonSteel
CarbonSteel
Colorado Springs
2023 Carbonized Gray
@malpais - Driver's side towards the rear on the upper side. It looks like a large nut.
@malpais (a quick edit):
Ford Bronco Change Driveline Fluids Early! Transmission Dip Stick
Here is the level (should be between 4 and 3 on the stick with the transmission at temperature and the engine idling in park):
Ford Bronco Change Driveline Fluids Early! 10R60 Fluid Level
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Which if it’s like the Ranger - it only gets to correct temp (190-200°F) for testing during ambient temps of 70°F+ and driving 10 or so miles above 70 MPH and/or hauling.
Roofus
Swamp
M3/Bronco
Just wanted to chime in here. This thread scared the S out of me. I’m at 23,xxx miles and we were headed out on a 4 day overland last week. So I had tranny and both diffs flushed and filled before we left and they found no metal shavings and all was well. Peace of mind + an oil change cost me a grand. Is what it is. But just fysa your truck might just be fine. But who knows…
CarbonSteel
CarbonSteel
Colorado Springs
Agree--TBH, I have no idea how you would bring it up to the 206°F - 215°F temperatures the service manual lists. I have never seen my temps hit that even climbing in the mountains.
Ducati1098
Set it a little low, drive until it’s around 180-185, then let it sit and idle. It’ll take a little while, but it’ll get to 200-205 then make a final adjustment
Dumb that they couldn’t give a level reading at a normal/lower temperature
CarbonSteel
CarbonSteel
Colorado Springs
I know. I have not dived into mine--pretty sure it is going tango uniform. It has repeated the "stuck in second" crap again and now it has a whine that increases with speed.
Something is going--I wish it would either go or throw code so that I can have it replaced.
JediMcMuffin
Tommy
2026 F-150 Tremor 401A
Yeah, I've held out as a skeptic here myself. I'm sure some people will see some metal, others won't. The discrepancies between the service interval recommendations are absolutely confusing. My Bronco is a daily driver that hits the trails maybe 5-6 times a year. I'm planning to get mine all flushed between 40 and 45,000.
Ducati1098
Any abnormal whine noise should be enough to claim low time in service and have it replaced. Unfortunately that all depends on your servicing dealer though.
CarbonSteel
CarbonSteel
Colorado Springs
I hear you. I have 9600 miles on it and there should not be any whining.
I need to find another dealer, but here in COS, there is only 1--I suppose I could drive it to Denver. I took it in today to have the trailer towing programmed and they could not find any settings in FDRS to do it. They went as far as to say the trailer brake controller module was bad because it did not light up (which it won't without a trailer being attached).
If they can't program the trailer towing package, can they replace a transmission...? Things that make you go hmmmm....
redone17
Cold Spring, NY
Wait…say what…a grand?! That’s like $150 in fluids.
Roofus
Swamp
M3/Bronco
Yeah, definitely won’t do it again before 75,000 miles plus. I’m like you 5-6 off-road/camping trips a year. And we’re definitely pretty hard on the truck when we’re out. But I’m thinking this is probably affecting the rock crawling crowd out west more than folks like myself.
Roofus
Swamp
M3/Bronco
it was outrageous. I would have done it in my garage, but unfortunately, I work out of state and we were leaving for this trip from my work condo rather than our house. So no garage prior to our overland.
To be fair, I just had 8 fillings done for $3,700… So the fluid change was actually quite reasonable by comparison. 🤦🏻‍♂️
just checked my receipt:
Oil change $122
Tranny flush $313
Both diffs $570!!
Looks like labor rate was $160/hr and they certainly did it strictly by the book.
