Change Driveline Fluids Early!
JBlanco
Julio
Charlotte NC
For those that are more visual, I found some videos on how to do this:
Transfer Case:
Front Diff:
Rear Diff:
Tor148
Tor
Cape May Court House, NJ
23 Braptor Bk, 21 FE RR, 15 F250,
Ordered this to install on the next fluid change. I went with it because I wanted a drain plug versus having to pull the cover every time (though I will pull it to inspect occasionally).
Do you have a link? I can only find it at one third party site and it is 200.
Model number?
Thanksn in advance !
CarbonSteel
CarbonSteel
Colorado Springs
2023 Carbonized Gray
Tor148
Tor
Bronco72
1985 Ford lariat F150
Is the drain plug on the Ford Performance cover magnetic?
Tor148
Tor
CarbonSteel
CarbonSteel
Colorado Springs
Yes; it is. Knowing how much metal these Dana 44 Advanteks shed for up to 25K miles or so, I will probably grab two more for the inspection and fill plugs.
Bronco72
That may be a good idea. Thx for the info!
orion
Jeremy
17' F-250, 17' Explorer
Done!!!
Used Ford points too!
Thanks again.
Same, 😆. I'm getting broker, and broker, and broker, and broker...
Yesterday it was the Ford Performance black lugnuts, Cyber Monday was a bunch of stuff from @StickerFab, and Black Friday was @Turn Offroad 's tire carrier!
Wonder what's coming for Christmas... 😬
Beach_Bum
St. Augustine, FL
2023 Outerbanks Bronco
The bills. 🥴
gtabert
Greg
Woodstock, IL
'18 gt350r / '65 f100 / '99 Silverado / '15 VW TDI
Here you go--these are for Jeeps, but with the exception of the IFS in the front they are the same axles (the rear is exactly the same except for mounting locations):
DS Front - https://d3qx1uccksbb2n.cloudfront.net/docs/SPECSHEET-JL-FRONT-UD44A-42019.pdf
DS Rear - https://d3qx1uccksbb2n.cloudfront.net/docs/SPECSHEET-JL-REAR-UD44A-D44A-42019.pdf
I am not able to comment on why Ford specs different lubes--but can say it makes zero sense.
No one has mentioned adding Friction Modifier? Looking at the attached links Front does not call for it / Rear does
CarbonSteel
CarbonSteel
Colorado Springs
Why? It's an electronic locking differential?
gtabert
Greg
Woodstock, IL
Good point, only questioned because the link you sent on the rear dif has that listed. I took it literally.
Thanks for clearing it up.
CarbonSteel
CarbonSteel
Colorado Springs
Dana covers both M220 ELD and Limited Slip with that spec--I should have noted that.
Thanks for catching it.
