Bronco battery confusion
Kevin Scarbel
Everglades
Kevin
Chesapeake, VA
2024 Bronco Everglades 4dr
Everglades
I have two 2024 Broncos with mid-packages.
That means they both have an inverter and AC 110V/400W outlet at the rear of the center console, paired with an inverter under the console.
However, the trucks have different batteries, and different hold-down straps. Why?
I can understand Ford having two battery suppliers (I assume they do). But not requiring different hold-down straps.
The simpler strap atop the larger battery, per Ford parts, is for Broncos with inverters.
Both trucks have inverters, and yet one has a smaller battery, and a hold-down strap with a tack-welded side piece limiting how far the battery can be mounted towards the engine.
This smaller battery's hold-down is listed for Bronco's without an inverter, though I have an inverter.
BAGM-48H6-760 AGM?, 70AH/760amp, LxWxH 10.84 x 6.825 x 7.41
BAGM-94RH7-800 AGM, 80AH/800amp, LxWxH 12.285 x 6.825 x 7.41
Without power inverter - https://www.fordpartspros.com/oem-parts/ford-hold-down-clamp-mb3z10a666a
With power inverter - https://www.fordpartspros.com/oem-parts/ford-hold-down-clamp-mb3z10718a
(Battery tray MB3Z-10732-A is same for both)
Given both trucks are mid's with inverters, I don't understand why both trucks don't have the larger 800 amp battery.
Heritage 02/24
Everglades 04/24
Ford Bronco Bronco battery confusion A34C440D-6696-4C20-9A54-A4BC851FAC8B
Ford Bronco Bronco battery confusion 85FD4677-73BA-4A53-B6DC-0D853B287DDC
Ford Bronco Bronco battery confusion 655EF435-5F65-418D-BE64-AF7C8977F9F1
Ford Bronco Bronco battery confusion D6865398-A5EC-4BDF-989D-12757095A8D3
Fordified1
Bob
Mid South Texas
Wouldn’t be the first time a manufacturer changed something mid year. Which one has the newer build date?
Edit. Are they both Everglades? Possibly one has heavy duty charging system and the other doesn’t? Which has to do with model not mid package or not I believe. (I’m just guessing at this point)
I have a BD with mid package and inverter. Jan 7 build date. I’ll see which battery I have tonight after work.
dgorsett
colorado
F250, Mustang, Explorer
I have a basic 21 BB, a friend has a 21 non Sas Badlands, IDK if he has an inverter. He has the bigger battery, I the smaller. When mine gives out I figured I'd get the bigger, and would need to modify of get the new hold down.
Fasteddy
Ed
Oregon
2023 Bronco 2 Door, 1992 F150 4x4
I have a 23 Badlands 2.3 basic package, no inverter etc. and has 800Ahr big battery...
Kevin Scarbel
Everglades
Kevin
Chesapeake, VA
Everglades
Heritage 02/24
Everglades 04/24
Both trucks call for alternator MB3Z-10346=Q........."2.3L with power inverter".
Fordified1
Bob
Mid South Texas
Heritage 02/24
Everglades 04/24
Which one has the bigger battery?
Kevin Scarbel
Everglades
Kevin
Chesapeake, VA
Everglades
Everglades has the larger 800 amp.
I can't locate the tag on the alternators (to confirm same or different) due to there being so many other parts crowding around it.
The 800 amp battery looks like a higher quality product.
The 760 amp is off-gassing. Acid fumes are clearly present.
PWillette
Parrie
Maine
Possibly larger battery for the Everglades winch?
Kevin Scarbel
Everglades
Kevin
Chesapeake, VA
Everglades
True. There was a time when US automakers listed standard (and optional) batteries with the CCA. Surely, Ford has technical specifications information.
Dreamer
Kevin
Connecticut
Ford Mustang GT convertible
Does the heritage have the auxiliary up fitter switches? I believe the Everglades comes with them. It’s an option on the heritage. Could it be possible the up fitter switches is the call for the larger battery? Just guessing.
I realize that's a joke but is it really? Would anyone be totally shocked if that was the case given Ford's history of QC?
Yup. It’s only a joke because there’s more truth to it than should be
BigHoof
PA
Ram 2500
From the Owners manual, the battery is different if you have the aux switches or the aux switches and a winch vs neither of them.
Ford Bronco Bronco battery confusion Battery
Fordified1
Bob
Mid South Texas
If that’s true, even as an add-on option, the auxiliary switches were already a bargain, they are REALLY a good deal if you get the bigger battery with them.
