Bronco battery confusion
Kevin Scarbel
Everglades
Kevin
Chesapeake, VA
2024 Bronco Everglades 4dr
Everglades
Fmuguira
Frank
Idaho
Jeep TJ
I think a guy from the old Escort line got moved to putting batteries in on the Bronco line … 😳😂
As mentioned probably aux switches/model difference. My BL has the switches and larger battery in it.
BigHoof
PA
Ram 2500
Kevin Scarbel
Everglades
Kevin
Chesapeake, VA
Everglades
That story is from before any Broncos were even built.
I realize "that" story predates Bronco. However the issue described in F-150s has been linked to Bronco, thru MY2024. I'm not arguing with you, rather just sharing information.
BigHoof
PA
Ram 2500
That's fine but do note that per a well respected service tech above, the battery has not changed. I think a lot of the problems stem from Broncos, F150s, f250s, ect sitting in yards waiting on parts due to the shortage mess. When delivered months later, the battery may have issues.
etmccaus86
Evan
Motor City
'22 BaseSquatch
Interesting thread, considering I'm contemplating replacing my battery after two years of living with "Low Power Mode On" statuses since new. Looks like I already had the bigger battery all along, since I had Aux switches from the factory...
Fordified1
Bob
Mid South Texas
Just because you have the bigger battery doesn’t mean you don’t have a bad one.
etmccaus86
Evan
Motor City
'22 BaseSquatch
Uh, thanks?
I didn't remotely imply that sizing meant bad battery. It's the constant "Low Power Mode" warnings since day one of ownership that would suggest it's questionable...
vancomycin
TX
Just another data point for others replacing their battery
I have a 2021 2.3L Base Bronco, no aux switches, no power inverter - turns out I had a stock H6.
My 3y warranty just expired and have been getting more deep sleep messages on my Ford Pass app, and "System Off to Save Battery" and "Please turn ignition off or start engine" messages on the display after turning the vehicle off. Most of my trips are short, but even after a long drive, my battery was at 12.14V when off, 10.05V lowest when turning engine on, and 14.53 at steady state when on. Wasn't a Dirt Mountain vehicle. When turning on accessories and revving engine, 14.3-14.4V. I decided to replace the battery, hoping this was the issue.
Relying on recs from Walmart/Costco/Amazon battery search tool and a very cursory search of bronco6g, I purchased an H7 battery, without looking at the specs of what was actually in my vehicle (my mistake).
When I went to replace the battery, I found the H7 fit, but the factory battery in my vehicle was an H6. The battery hold down was as described on page 1 of this thread with the extra side arm that prevented it from securing the H7. Additionally the felt wrap around the battery had to be opened to fit, which should have been my first indication of the size mismatch. I had to bend the metal side-arm out of the way to secure the battery hold-down.
Looking back now, this is one of the few threads I can find that even mentions some of the Broncos having H6 size batteries and the different sized hold-down. Just a heads-up for the few others who might be in the same situation when replacing their battery!
Kevin Scarbel
Everglades
Kevin
Chesapeake, VA
Everglades
We all definitely gained some nice-to-know knowledge on the Bronco's battery specs.
8rent
Brent
One more data point: I have a 2023 2 door heritage, no Aux switches, so I have the 760 amp battery. I bought it new in Jan 24 so I have had it about 18 months. It has 8833 miles and is always garaged - I'm retired. Started getting the battery error messages. Then I got a check brake system message. Took it to Ford today. He scanned the vin and could see all the error codes including transfer case and 4wd errors. They tested the battery. It was at 30% capacity. They replaced it under warranty and cleared the codes. Everything works great now. Apparently a low battery can cause a boat load of error codes. I have never had a battery fail so early, but it was a quick fix.
FerkinBlonco
AK
2008 KLR 650, 2022 Bronco Base (2dr/7mt/CO)
I just had the same experience on my ‘22 base. Picked up an H7 and I was very confused until finding this thread, haha. I bent the retaining plate too, and am contemplating just buying the part sans retaining end + the bigger blanket… because OCD I guess. New batt seemed to do the trick of eliminating the constant low power mode shutdowns, at least.
Base, 2.3, no AUX switches
