Brakes running hot lately
dadjoke
Southern California
'22 Bronco Big Bend 4-Door 2.7 MIC Auto Sasquatch
Hey, yep it's hot out. But IMO my brakes, specifically Driver Front brakes are too HOT when I get where I'm going. It's been happening maybe a week? I can drive 10+ mins and then it smells like they're burning, obviously the longer I go the hotter they seem at rest (there was smoke briefly once), but I've had it since '22 without this issue ever having happened before.
It's a '22 Big Bend 2.7 Sas, and the only thing that's ever happened regarding the brakes before was ~2-3 months ago the front passenger line blew out entirely. (Replaced at dealer)
Yesterday I took off the driver's wheel and did a quick inspection, everything looked fine and seemed to move freely? It's not pulling driver on or off the brakes, they otherwise are seemingly working ...as normal? I'm not hot dogging or doing anything crazy/fast.
I suppose my next step is to take the caliper off and inspect the pads, but I wanted to check in here and see if anybody had other thoughts or ideas? I'd really like to resolve this.
bendover
BMW M2, Bronco Badlands
it's gotta be the piston in the caliper dragging if the pads look ok.
MilesTeg
United States
2024 2DR Badlands Manual/VB, 2018 F-150 Lariat/3.5EB, 2013 Mustang GT DIB
If you are seeing and smelling smoke, there is something very wrong with your brakes. Assuming no driving abuse, there's no reason you would experience that without something like a sticking caliper or other mechanical fault.
CalvinT
Calvin
Phoenix, AZ
Is there any reason it can't be a wheel bearing?
(Old guy old times experience might not apply)
If it was a wheel bearing getting hot, you'd hear it.
CitrusBronco
Everglades
Citrus county, FL
Everglades
New boots with a wider footprint? You’re clipping the brake pedal and driving with your brakes on.
Just a thought, I’ve seen it happen.
Valhalla
Valhalla
Chattanooga Tn
Are the pad clips intact? It could be they have broken off letting the pad drag. (Mine did no smoke but premature wear.)
That would be my guess as well as there have been a few reports of this in particular occurring on Broncos
SHANUT
Craig
Hermann, MO
My daughter is a nut when it comes to braking because she has brake dust and you should never have brake dust if you know what you’re doing but one time she did have overheating brakes, and it turned out to be a collapsed brake line.
MayhemMike
Mercury
The rubber rake line suffers an interior collapse of the rubber and the pressure applied when braking doesn’t get released due to the collapsed interior of the brake line acting as a dam. Exact thing occurred on my F 150. Rubber brake line replaced, problem solved.
Oilbrnr
Scottsdale, AZ
'97 factory locked LX450, '16 Power Wagon w/FWC, '25 Bad/Sas/7MT
Could be a flexible brake line on the DS. But the OP really needs to take to an independent trusted shop and have the issue addressed before more damage occurs. If there was smoke, rotors might be toast and I’d also do a fluid flush.
rbroncotx
Rob
TX
Bronco Raptor 2021, Jeep JL 2024
Nobody's said slide pins yet — pull the caliper and check both pins move free and the boots aren't torn. A seized pin will hold the pad on the rotor and cook one corner exactly like this.
Nick72
Nick
North GA
2021 Bronco Base(Traded), 2025 Bronco Outer Banks
Well, I guess I'm doing something wrong because every car I've driven for the last 40 years has has brake dust. It didn't matter if I drove like a grandma or drove the brakes off of my patrol car during chases or hot calls.
Please share your method because I'm tired of cleaning brake dust off my wheels and can save some money by not having to buy wheel cleaner! 😁
VirginiaHeritage
Frank
‘25 Bronco HE
I witnessed smoke and brief, minor flames from the wheel of a lady’s car in a parking lot when she pulled in from the road. I ran over to warn her.
It was the parking brake.
Daniel Hochleutner
Daniel
IL
2022 4 dr Bronco red
When I first got my 22 big bend the bakes felt weak..I put red cover on calipers they seem to be too small for that vehicle. In my opinion, the calipers on that vehicle need to be bigger. That’s what’s wrong with it.
