Brakes running hot lately
Valhalla
Valhalla
Chattanooga Tn
Please share your method because I'm tired of cleaning brake dust off my wheels and can save some money by not having to buy wheel cleaner! 😁
Easy buy lifetime pads, they will never wear or make dust.... You will replace rotors every 3 years...
Nibroc99
Corbin
Rochester, MA, USA
www.corbonthecob.com
2022 Wildtrak: The WildeBeast
When's the last time you cleaned and re-applied silicone grease (line syl-glide) to the guide pins? And have you ever taken the pads off to clean the slides/slide hardware? This should be considered normal maintenance every 25k miles or so. When I got my bronco used at 58k miles, I changed every fluid in the thign and lubed the brakes - the guide pins were covered in hardened black sludge, which I cleaned off with a wire brush and some brakleen, and re-lubed with syl-glide, just like I said. The rears were in the same condition.
