BILSTEIN SHOCKS Destroyed
JT58Bronc
JT
Fl
Definitely not a good design. I live in FL but very rainy summers and high humidity they may not last either.
Rick U
Are the 6100’s a direct replacement for a Sasquatch? I do not want to change the height.
carrellslake
Oregon
2022 Ford Bronco
Is this a rust belt only issue?
No. I live in a high desert and while my reservoirs haven't fallen off, they all have discoloration around the reservoir like fluid is weeping out.
Y2KFirehawk
PA
2022 Bronco Wildtrak
I wonder the same. Retain springs swap to 6100s? I feel like I read about the 6100s so much but still not certain of this answer.
CarmeloS
Carmelo
Central Jersey
Aonarch
Jack Hoff
MT
Both technically incorrect.
The black piece saying "BILSTEIN" is a plastic sleeve that covers the reservoir. Probably protects from small rock strikes but I bet it also traps moisture exacerbating the issue.
This is my '23 bought late July 2023. So only one MN winter on them, and I am religious about winter carwashes that spray the underbody off from salt and grime during the winter months.
Already rusting in the gap bewteen rezi and shock body. I spray some oil on them to try and prolong the inevitable.
I'd ditch the plastic and put a metal hose clamp around the shock and reservoirs.
6100s are the way to go. Swap over springs, top hats, etc and off you go.
60mm bodies, no reservoir needed unless you are racing in Baja.
[DELETED MEMBER 27901]
Yeah, you can bet your ass my Hitachis will last forever!!!!
Didn't even have to pay extra for them!!
Unfortunately, the plan is to change out to some good ones with a lift whenever they wear out .....
Manual transmissions grinding, Bilstein shocks exploding, hard tops delaminating....
Meet the 4dr auto OBX...the real king 🤙
Ford Bronco BILSTEIN SHOCKS Destroyed 1719946544959-
CarmeloS
Carmelo
Central Jersey
Got none of those issues, all hail the Real Bronco
Ford Bronco BILSTEIN SHOCKS Destroyed IMG_5699
Poppavein
Redmond, WA
Harleys, Ducatis, 2024 Bronco
6100s require Sasquatch springs. I believe the shocks are adjustable so you can maintain the same height.
Aonarch
Jack Hoff
MT
Yes, they have 6 points of adjustability. They take your factory Sasquatch springs, so same spring rates.
In the instructions it will tell you what position to place the shocks in for the ride height that you want.
JBlanco
Julio
Charlotte NC
FIRST TIME I'VE SEEN THIS!
today...
