Best FORScan changes to make?
Bill K
Bill
Allen, TX
Ford Bronco Big Bend 2 Door
Speaker adjustments after upgrading
Enable foglights after changing out Factory Switch and installing foglights
Disable panic button on key fob
helifino16
Ron
Mount Sinai, NY (Long Island)
I turned on the Fog Lights w/DRL and High Beams. Now they are on all the time.
Ninjak
Miami
Depending on what you have, the B&O cannot be adjusted with Forescan. As for me,
Badlands: Global window up, double honk eliminated, sport mode added.
Strizzo
Bryan
Houston, Tx
Lexus GX460, 1966 Mustang Convertible, Jeep Wrangler TJ
I just did the replacing of the fake sub/amp in my 2023.
Now that I have FORScan, I was wondering what are some changes that you all made that you recommend?
Figured now that I have FORScan for 2 months, I might as well use it some more.
Depends what you want to do. You can add a headlight switch with front and rear fogs and use the rear fog wiring for a chase light. You can do the global window close change that closes all the windows when you lock the car.
I got rid of the seatbelt chime and double honk when you get out with the car running and close the door since we do a lot of riding around at the hunting lease getting in&out.
AZ_Liberty
2007 Expedition
Disable ASS
Disable Double-honk
Lots of folks also like global window up from the FOB, which I would have no use for. I really want a global down with a 3 second press instead of the 7 which feels like 20.
NoloBronco
Nolensville Tn
2022 Bronco Badlands SAS
Is this using the current stock rear speakers?
Watch this video for guidance. The modifications I made were following @RagnarKon lead. He does mention in the video that removing the audio filters for the stock rear speakers may not be the best idea. Overall good video and instruction.
Pretty good overall improvement changing all the speakers out while also adding the sub and amps.
The biggest improvement was noticed after the ForScan mods were made and sub and amps were installed.
CMillBronco
Craig
2024 GMC HD 3500 AT4, 2022 Toyota Tacoma TRDORP, 2023 4Runner TRDORP
After you watch the video above it will make more sense, I had the sub delete as well but changed out all 6 speakers to Kicker CS's when doing the sub. For Forscan I ended up updating 2 things in the ACM module, 727-01-01 changed 14F1 to 28F1 the 2 enables speaker and tweeter from 1 being tweeter and the 8 does the same. The second change was same ACM module 727-01-02 went from 0901 to 0900, this change removes the EQ that limits sound to the rears. After these changes the system sounds way better!
Ragnarkon has another video on the fronts being to bright which I agree with and I might did into that next but it sounds much better than the B&O now.
Dusty
Mentone, CA
70, 71 & '21 Broncos
If you go off-road and air down your tires, use Forscan to lower the low tire pressure warning threshold.
mpeugeot
Disabling all the annoying chimes, including seatbelt chimes.
murphtron
T
Berkeley, CA
2023 Badlands, 2013 Toyota Highlander, 2000 Miata
can amber be added to the signature lights' horizontal slash so that it is on while daytime running lights are in use?
Yes. It’s available in the « plain English » section. Easy to update. Note the amber slash only works when it’s running in DRL. When it gets dark and headlights are on they revert to white.
rii_505
Ricardo
PR
do you have a tutorial or the forscan codes I need to change?
Thanks
mikec426
Russellville, AR
22 4dr Sqtch, '04 Yam FZ1, 22 Versys 1k, 19 Ninja
It’s called Bambi Mode quite a bit. There’s YouTube videos for it.
helifino16
Ron
Callelk
Larry
Idaho
Escalade ESV, Cherokee 2-Door
I did not see that in the spreadsheet. Do you have more info?
....nevermind, found the thread............
Dusty
Mentone, CA
No, I found the information in a search, and implemented it without writing it down. The information is out there.
