Odd chime after making Forscan changes (Resolved)
Wiegmanc
Christopher
Essex, CT
2023 Ford Bronco
I added two GOAT modes (Rock and Baja) and changed the key fob panic button from one two two pushes and now when I turn the Bronco off, I get a weird single chime. Anyone know what this chime is? Any help is much appreciated!
Wiegmanc
Wiegmanc
Christopher
Essex, CT
2023 Ford Bronco
I tried resetting fault codes using forscan, no fix. I then tried disconnecting the battery for 30 seconds, no dice. I would have recovered from a backup but I cant find my backup files from a year agao when I made them1
You can try getting your as-built files
https://www.motorcraftservice.com/AsBuilt
Word of caution - this is called as-built, but it gets updated via your cell modem every so often. So it isn’t actually as-built… more like “since we last updated our files”
So you might get lucky and be able to snag the settings from before you monkeyed with it
Wiegmanc
Wiegmanc
Christopher
Essex, CT
2023 Ford Bronco
I'm an idiot. I have a dashcam and I recently activated parking security mode. The chime was the camera going into parking mode after the car is turned off....
Wiegmanc
Wiegmanc
Christopher
Essex, CT
2023 Ford Bronco
Thank you!!!
