Rear Speaker Pod Replacement - Forscan Changes
mig1980
El Dorado Hills, CA
2016 Corvette Z06
I have search the web for my scenario but didn't find a clear answer. I am looking for confirmation before I make changes.
I am starting to replace all the speakers in my 2023 Wildtrak (standard audio - non-B&O) with Kicker speakers and amps (including a 500.1 and 200.4 Key as well as an 8" sub). I am starting today by only replacing the rear pods with 6.75" Kickers. No amp change.
In order to get them to sound better, are the Forscan changes I need to make the following?
• ACM 727-01-01 (change second hex to 28XX)
• ACM 727-01-02 (change first hex to XX00)
I am also looking to enable the turn signal speed sensitive volume on the IPC module.
