Best FORScan changes to make?
TTUHoopsFans
Bill
Frisco, Texas
2023 Ford Bronco
I just did the replacing of the fake sub/amp in my 2023.
Now that I have FORScan, I was wondering what are some changes that you all made that you recommend?
Figured now that I have FORScan for 2 months, I might as well use it some more.
KhoiPhish
Altima
What'd you have to do for the fake sub/amp?
My favorites are adding GOAT modes, removing double honk, disabling start/stop.
Warnock
Randy
New Jersey
Hyundai Genesis
Does the auto stop disable work on 23 broncos?
BigMeatsBronco
Allan
2021 FE 2 door
add goat modes or (take one away)...
adjust for different tire size... if needed.
turn on Stop &GO (if you have adaptive cruise control)
TTUHoopsFans
TTUHoopsFans
Bill
Frisco, Texas
2023 Ford Bronco
Thanks. Just had to activate the sub and change 2 characters on a certain line. It was super easy.
TTUHoopsFans
TTUHoopsFans
Bill
Frisco, Texas
2023 Ford Bronco
Do you have specific instructions on how to change double honk? I saw the google spreadsheet but I didn’t quite understand all the xxx* stuff and I don’t want to mess anything up.
ThatWilsonGuy
23' Raptor | 23' BL SAS | Sport FE (sold)
Disable double honk
Window roll up from key fob
Ambi color floor lights (hardware required)
peterh
ny
jeep wrangler jlu 2018
can amber be added to the signature lights' horizontal slash so that it is on while daytime running lights are in use?
BBSas
Alabama
Disable double honk
Add Goat modes
Speaker adjustments
Sardine
2022 Elantra N - 6 speed & 2023 Badlands
I turned the turning signal volume down. I didn't do a before and after comparison but I THINK it worked. Doesn't seem to be that much lower.
Spiderwolf
Mickey
woodstock, GA
2012 Rubicon, 2016 Dodge Challenger RT Scat Pac
Spiderwolf
Mickey
woodstock, GA
What do you mean fake sub and amp. I’ve seen this mentioned before and don’t understand what’s going on and how FORscan helps. I have a 2023 Bronco Raptor with the B&O system and I think it sounds pretty good. Did you order yours without any sound system upgrades and Forscan helps with that or Will FORscan help with the B&O system and how?
TTUHoopsFans
TTUHoopsFans
Bill
Frisco, Texas
2023 Ford Bronco
Constraints led to a sub delete option on many 2023s:
https://www.bronco6g.com/forum/threads/fake-sub-amp-now-what.80162/
NoloBronco
Nolensville Tn
2022 Bronco Badlands SAS
Change the audio settings on the rear speakers of upgraded and equalizer settings.
Add sport mode if you do not have it
Remove double honk
