What changes have you made to your Bronco using ForScan?
FordMedic
Bill
Ann Arbor
2023 Bronco WildTrak
Bikeric
Tulsa
1984 4Runner (For Sale)
Tire circumference, TPMS set points and Signature tail lights to Oracle.
timhood
Tim
Several
Tire size and TPMS
Global Window open/close
Changed key fob panic button to double-click
Reduced heated steering wheel temp 1 degree C
Disabled double-honk just because I was already doing other stuff
Set speed-sensitive turn signal volume (but I don't notice a difference, nor do I really care)
Added Sport mode (but I've only used it once)
I've listed the above in the order that I have found them useful. The first one (which is two separate settings) was helpful because my "daily driver" tires are a different size than my off-roading (stock) tires.
Shane78
Shane
St. Louis
2D
Tire size and TPMS
What is this global window open close thing? I know about the double click and hold unlock to open windows, but close?
Shane78
Shane
St. Louis
2D
Same thing… just click and hold to close the windows.
It’s turned on by default in some Ford vehicles overseas so the settings are there. Here in the USA we worry about stupid people chopping off their fingers and whatnot so it’s only turned on for vehicles that have a safety feature to prevent that from happening (which off the top of my head is only available on some of the Lincoln’s).
Never knew about that, but you gotta have forscan to turn it on?
timhood
Tim
Several
Yeah, there's no setting/control for it anywhere within Sync, which is like a lot of these options. Why not just put these in the Sync menu system?
One thing I'd like is to be able to control the number of turn signal flashes that a half-press initiates. I've seen in other cars where you can set it to 3, 5, or 7. (Not sure what's wrong with 4 or 6--if this were my software, I'd give an option between 3 and 7.)
myrealname123
Trent
Monterey, CA
'21 Bronco
Tire size and TPMS
I had this on my 2018 F150 Raptor and was wondering if Ford just did away with it. The standard turn signal volume was a quiet tick tick and when your speed went over 45mph it was pretty much the volume it always is on the Bronco now.
timhood
Tim
Several
OK, I'll have to play around with low-speed/high-speed turn signals and see if I notice a difference. On your F150, if it was set to off, was it in quiet mode or loud mode all of the time?
myrealname123
Trent
Monterey, CA
'21 Bronco
I actually never got in and messed with it on the F150, that was how it came from the factory.
Danh63
Dan
Ohio
BMW X4, BMW 840, Chevy Trailboss
Sub rear amp turned on
added some GOAT modes
Still want bambi mode and disable double honk and would love for someone to figure out Auto Start/Stop for the 2023's
Have a question RagnarKon or anyone else that knows. I have the Fusion amp kicker 4 ohm sub should I do the
EQ Settings - ACM 727-01-02
  • xxYY-xxxx-xxxx
    • 00 = EQ Off
    • 01 = EQ On (High-pass filter on the rear pods)
Currently mine is set to 01? Not exactly sure what this one does.
amccue90
Andrew
Illinois
2021 Badlands
I'm almost positive I saw this going through the forscan
Mean Red GT
Kevin
TN
2022 4 Door Badlands/2016 Mustang GT PP
Disabled ASS
Disabled double honk
Added Sport Mode
Adjusted tire size for speedo
Added global windows up
Increased heated steering wheel temp
BroncoDymond88
New Jersey
Kia Sorento
I turned off the double honk when you get out with the keys and enabled windows down and windows up from the FOB. Both are GREAT.
najay
southern california
boss 302, focus st, gen1 lightning, f250 7.3l 4wd
Disabling Auto Start/Stop in the PSCM (Disable Auto Start-Stop PSCM 730-03-01) does not work on my raptor.
timhood
Tim
Several
I saw it listed in the spreadsheet I have, but it is wholly struck out, so I assume that the original info may have been copied from F150 or another contemporary Ford and then found not to work.
