- First Name
- Jared
- Joined
- Feb 20, 2023
- Threads
- 45
- Messages
- 7,096
- Reaction score
- 13,832
- Location
- Denton, TX
- Vehicle(s)
- 2023 2dr Badsquatch
- Your Bronco Model
- Badlands
Here's some tire recommendations if you want beefy looking, no particular order:
- BFG KO2
- Goodyear Territory A/T
- Mickey Thompson Baja Boss
- Kenda Klever
- Goodyear DuraTrac
- Falken WildPeak
- Toyo AT3
- Nitto Recon/Ridge/Trail Grappler
- General Grabber
- Maxxis Creepy Crawler (ha ha, just kidding)
- (Whatever I've missed.)
Now make a spreadsheet, add only the tire models that are in your size and SL or C load rated (D if you really like the tire), then put a column for the weight of each tire. Sort once you have that column filled in, lowest at top. If you can afford/like any of the tires in the top three, you should probably lean towards that tire.
Also, keep in mind if you do go actually bigger than what you have now (a 33" is not usually 33", it's usually 32.?), you'll need to realign and calibrate your speedometer. You can do the latter with the Ford Performance Tuner, which you'll probably also want if you're going heavier (for the small but noticeable extra oomph).
- BFG KO2
- Kenda Klever
- Goodyear DuraTrac
- Falken WildPeak
- Toyo AT3
- General Grabber
