5" inch lift?
CitrusBronco
Everglades
Citrus county, FL
Everglades
Have you EVER placed a drop bracket up against a rock?.... They sure do NOT slide over very easily.... In fact they act like a great big anchor..... I can slide a stock bronco with 35s over a rock using the skids.... The Drop Bracket will NOT just slide over rocks... Show me a drop bracket skid.... I have seen a couple of home made ones... BUT NOTHING on the market. All for 1 or maybe 2 inches of clearance.... While that is a lot of clearance starting at 11.8 inches, I will take the full skid over a drop bracket any day of the week. That is the point of the Bronco..... It is ready. If you want to improve it, that takes a hell of a lot of money because there are NOT any quick easy, inexpensive improvements to make.
Sure a drop bracket allows a much larger tire..... for looks. I honestly think a drop bracket lift actually makes the bronco LESS capable. But what do I know.... I have never been off road...
I think you missed the point of my post, portals are just unobtainable for many people.
I agree with your points however keep in mind not everyone has rocks to craw over and the drop bracket is still higher than a solid axle is from the ground when you’re plowing through mud and snow.
If rocks is your game you certainly should look at other options besides the drop bracket.
5GENIDN
Idaho
I live in Idaho.... EVERY run (other than a forest service road) has some rocks or huge wash outs that may only be dirt but act just the same.... I have a drop bracket on my truck (my first IFS ever on a 4x4) that damn thing is a snow plow blade. And No... it is NOT higher than a solid axle... at least not much... MAYBE an inch? It extends below and cradles the pumpkin. It extends all the way across from lower control arm to lower control arm.... A pumpkin is in ONE spot.... The axle tubes ride several inches higher. Now if you could put a skid plate under it.... Now you are talking.... That would help dramatically. But right now you are going to custom make that.
CitrusBronco
Everglades
Citrus county, FL
Everglades
The only way to gain ground clearance with a SFA as you’re aware is larger tires so wheel placement is needed to keep from hanging up. That’s really no different with IFS and a drop bracket, wheel placement still matters. Skid or no skid it’s best to avoid plowing into rocks, unfortunately it can’t always be avoided as you point out.
Which lift are you running?
I bet you have some great wheeling opportunities in Idaho, what a great place to have a Bronco.
PetePerkins
Pete
TN
2024 Black Diamond
I never claimed to have first hand experience with their portals, so lets clear that up. You do, which instead condescendingly saying "I'm ready to learn", you could have said that from the start.
SO let's get the d**k measuring out of the way, I am an engineer and I've designed custom gearing solutions on million dollar automated systems. I'm not an idiot who thinks marketing phrases mean anything.
Yall coming at me hard because I think it means something that 74Weld races with their portals is wild. Again, to me that just means they've had to make a product that works because if they didn't, you better believe they'd be getting dropped. There's nothing worse in racing than losing, and losing money, because stuff breaks down.
Do I think all their stuff is "race level" of course not, but if you're designing parts for race applications, again, lessons get learned and re-applied to other products.
Now, my guess @SierraBronco is that you have a specific rub with Quinn or someone else at 74Weld (beyond the issues you've seen with leaks, I didn't go through all your threads because I don't have 3 days to read all of that rn). When I had a phone conversation with Quinn sometime last year, he specifically made it a point to tell me how much better portals were than IFS long arm kits. You are apparently working on an IFS long arm kit of some sort, so I'm guessing that is part of the hostility toward anyone who dares say they think 74Weld is quality. Honestly, I don't even know if Quinn is still there, but it certainly sounds like there is an axe to grind against someone over there...
So, back to my first post in this thread, someone PLEASE PLEASE PLEASE tell me why a drop bracket suspension is better than portals. I still haven't heard an argument to that. If you wanna talk about full IFS long arm suspension, that's a whole separate argument, one that I haven't expressed any opinion on at this point...
There he goes again! Calls someone a crackhead and now playing the victim...he can't help himself. Hilarious. Ok I'm out, I need to find a puddle to drive through with my snorkel lol
5GENIDN
Idaho
On my truck (2009 GMC Canyon) I am running a Rancho 5 inch with a custom spring over in the back....
My Bronco I have 74 weld portals and King coil overs.
This was this last weekend.(Saturday)
CitrusBronco
Everglades
Citrus county, FL
Everglades
Beautiful country, I kept expecting to see a mule deer step out on the trail.
5GENIDN
Idaho
There are quite a few... A whole bunch of wild horses as well.... although they are usually in the rolling hills just below this area....
If it’s just to look cool - get the ProComp
Coil overs, crank the adjustment to max - and that’s not far off from 5” of lift right there. Your front CVs will stay within safe bounds, no crazy brackets required, and you get semi-close to HOSS 2 level performance without the risk of a reservoir falling off.
You will need UCAs and a rear trac bar bracket, but there are inexpensive options there.
(This is not a great idea, just for the record, but it would work and it isn’t Portal money)
Oldhippie
Barry
Santa Cruz, Calif.
My guess is the OP just wants a big lift and 38”s on 24”s to look kool, so the RC lift would be just fine….after all that is what it was designed for…party on!
Jdyount
Jason
Kansas
2021 Badlands
I’ m your huckleberry, I want in on the gangbang.
The drop bracket is superior due to $$cost which allows everyone to participate.
Ignoring the fact that the high cost of the portals themselves is outside many people’s budget they also require frequent service to maintain, plus other upgrades to the truck which raise the cost even more. So for most people portals are to damn expensive and have no business being brought into a conversation about normal budget lift options.
😉 I did my best to answer that for you.
You didn't read the whole thread. The context was other than cost. Yes portals are very expensive, yes they require more maintenance, but they are a superior option. Dude I originally responded to said he would rather have a drop bracket lift vs portals, given that you have the money to have that choice, portals are far superior.
Also, the only lift a drop bracket gives you is moving the axles away from the frame. It doesn't provide any additional ground clearance. You can already run 37s or 38s with a standard 2"-3" suspension lift, a 5"-7" drop bracket only lets you run 40s if you wanna trim body, a LOT. So really there is no big advantage and you're much better off not messing up your center of gravity and staying with a regular lift, or going to portals for a few extra inches of clearance if you have the money, or there may be some other options to consider, like long arm IFS.
The one thing drop bracket lifts are good for are for people who love the mall that wanna "look" like they off-road. You could probably stuff 40s with enough wheel spacer, if you NEVER articulate the suspension, or turn very hard...
Jdyount
Jason
Kansas
2021 Badlands
Lets see some pics of you putting that snorkel to good use! Tell you what, I'll post a water crossing pic first.
Ford Bronco 5" inch lift? 1756214687382-hi
SierraBronco
Portal drawbacks (covered more thoroughly in the portal review thread) :
Cost, as mentioned already
Maintenance, as mentioned already. Some manufacturers are easier than others
Added complexity. If you can’t wrench on your own stuff you might have a bad time if you run into a problem on the trail.
Scrub radius
Unsprung mass
Significant increase of stress on suspension mounts
Suspension kinematics wrecked
COG increase
Depending on the company, proprietary parts that can only be sourced from the company.
Portal rigs start bouncing sooner than conventional rigs. Especially those using rubber in their rod ends.
Surface leaks are annoying, but axle seal leaks are not fun. Pushing portal oil out and into the axle housing, but unless you diligently watch temperatures-you won’t know it’s happening.
Can’t weld on the billet options
No increase of articulation. You only gain clearance and the gear reduction.
The drivetrain stress reduction is significantly exaggerated and only applies when the tires are spinning.
PetePerkins
Pete
TN
2024 Black Diamond
I'll post a pic of me and your .... creating our own water crossing. Try contributing to a conversation without showing your lack of maturity, social skills and respect.
CitrusBronco
Everglades
Citrus county, FL
Everglades
I read it all and just wanted to join in on the fun argument I mean discussion.
portals rock if you can afford them otherwise they don’t even exist as a option.
rock on portal gods, your machines are bad ass. Maybe one day I’ll be able to join in.
Valhalla
Valhalla
Chattanooga Tn
To the OP, Body lift, slight suspension lift gets my vote. We are waiting on intend use and long term use plans. I'd stay away from rough country unless it will never see offroad and you don't care about diminished resale. I actually think a small drop bracket is a good idea for the cv's and for more articulation. I have broken a CV which Ford replaced. (using turn brake, lesson learned). I don't think you are looking at portals, but I'd look at the discussions on here about them. I'd look at BIGMEATS build as he did some drop bracket low suspension stuff to do 42's. If you are wheeling you need to seriously consider upgrading the drive line to handle anything outside a 37. You can run bigger with abundant caution and the knowledge that you will have premature failure on components.
I wheel as often as I can, I have a long-term build that will go to 39/40's. Money is the only thing in the way. I plan on the ultimate front and rear and going wider on the arms RCV axles and 2" lift.
Hope this helps...
I guess I need a water crossing pic and a pic of some offroad...
Ford Bronco 5" inch lift? 20230114_110148
Ford Bronco 5" inch lift? scan0019
Ford Bronco 5" inch lift? Resized_20231028_101743
