- First Name
- Brian
- Joined
- Sep 14, 2023
- Threads
- 64
- Messages
- 8,800
- Reaction score
- 15,706
- Location
- Central CA
- Vehicle(s)
- '23 BB 4dr 7MT, '22 BSport OBX, '87 B-II XL
- Your Bronco Model
- Big Bend
The engines have a bit of memory for octane/knock - but that doesnt really affect drivingDo we know whether these engines are a type that "learn" driver behavior? I thought I remembered reading somewhere that some engines start anticipating what you're going to ask for when you do certain things, and tune themselves accordingly to e.g. reduce emissions or fuel consumption. Since you're driving stick, it obviously isn't the transmission doing anticipatory shifting and power modulation, but perhaps it's gating the throttle somewhat for some other reason. You could also try Baja mode with some manual adjustments to off-road settings.
I find in mine that in "standard" mode, I need to goose the throttle quite a bit when starting out, or it looses too much power getting going as the clutch comes out.
The transmission has adaptive learning which can adjust shift points over time; that is significant enough that I can notice if someone else takes it for a drive to the store and back that it has adjusted.
